4 speed hump
Old Aug 15, 2010 | 07:19 PM
1970_442's Avatar
4 speed hump
does anyone have a picture of what the bottom of the hump should look like in a 70 442 i want to get the size of the hole right so it looks factory (although no one will ever see it).
any tips would be great
thanks
Old Aug 15, 2010 | 08:35 PM
70Post's Avatar
I'll try to post pics I took from an original '70 4 spd car showing the factory cutout in the floor.
Warning....it isn't pretty...they used a torch and the hole is fairly ragged....you said you wanted "factory" so that's what you'll get in these pics.
Stay tuned.
Old Aug 15, 2010 | 08:51 PM
1970_442's Avatar
cool thanks
Old Aug 16, 2010 | 02:02 AM
jensenracing77's Avatar
the factory hole is far from pretty.
Old Aug 16, 2010 | 08:14 PM
1970_442's Avatar
this is the hole that was in the floor when i got it. i thought from looking at it someone had hacked it in but now im not sure. is this what a hole from the factory would look like? is it possible that i have a 4 speed car?when i got it it had a th350 in it from who knows what and a column shift and i know the steering wheel wasnt original
Old Aug 17, 2010 | 02:03 AM
does it have a hump welded to it on the inside? that don't look like a factory job with the holes around it.
Old Aug 17, 2010 | 08:09 AM
1970_442's Avatar
thats how it looked when i got the car. my guess is they drilled the spot welds and removed the hump. also i got a hump from another car to add on and it lines up with that hole and the holes that could be from the spot welds line up as well.
Old Aug 17, 2010 | 11:08 AM
MN71W30's Avatar
marxjunk
Feb 20, 2015 07:25 AM
66 W 30
May 5, 2012 08:59 AM
CutlassLegend
Sep 13, 2011 06:50 AM
madd442
Mar 18, 2011 10:53 AM
F-85 4-4-2
Sep 30, 2010 03:57 PM
