1972 CS Acceleration Problem..
I am having trouble accelerating seemingly past 2nd gear, the car rpms & sound just increase but the speed does not. I am approx going about 15-20 mph when the car's speed will not increase, Any help would be appreciated as usual. Yes I have enough Trans fluid. No other noticeable problems like sputtering while driving or misfiring just the increase in speed.
DT
DT
not entirely sure if it is even the 2nd gear. Trans fluid red, less than 6 month ago flushed all fluids and replaced, it is rarely ever driven. This issue was not present up until recently. Burning smell is present.
A burned smell to the fluid, when it was flushed just 6 months ago, is not a good sign.
Count your upshifts to see if it's shifting out of first into second. My guess is it's not.
How's your vacuum modulator and lines?
I have never been a fan of
flushing the transmissions and converters.
Filter changes only. I have heard to many
horror stories after 6 months or less on a flush.
All of them involving a rebuild.
I moved this out of the newbie section.
Is it full while it's running and warmed up, in park? I'm with Eric, check and make sure it's actually shifting. It may be the modulator or the hose to it. It can also be the cable for passing gear is stuck.
82 Grocery Getter
May 10th, 2009 09:57 AM
