1970 turbo 350 kickdown cable?
Old Oct 30, 2015 | 10:32 AM
JOHNNYOLDS442's Avatar
Olds Specialist LOL
Hey all i think i know this is the 1970 turbo 350 kickdown ran by a cable?
passenger side of tranny to the driver side of carb?
does this control the upshift or just the passing gear
Old Oct 30, 2015 | 10:56 AM
Olds Specialist LOL
OK guys I located the cable on the passenger side of the tranny and it goes to the Excelerator pedal check out the picture. I thought the turbo 400 so only like that it's definitely a turbo 350 it has the square pan with that one corner cut off and I know the turbo 400 pan is it weird shape.
Old Oct 30, 2015 | 10:59 AM
svnt442's Avatar
They didn't put the cable to the carb until later. The TH400 uses an electric switch and a solenoid, not a cable.
Old Oct 30, 2015 | 11:39 AM
Olds Specialist LOL
Correct that is why I posted that picture that has it going to the throttle gas cable[
QUOTE=svnt442;869205]They didn't put the cable to the carb until later. The TH400 uses an electric switch and a solenoid, not a cable.[/QUOTE]
coppercutlass's Avatar
Chevy budget Olds powered
the kick down controls the downshift. I have a th350 in my 72 and when I built it I left the cable out and plugged the opening. I manually downshift which is easy with a competiton shifter .the trans will down shift at lower speeds like coming to a stop still .,but not during accelration.
eazy
Dec 16, 2014 08:47 PM
at3reg98
Jul 4, 2012 10:14 AM
rocketscientist
Mar 11, 2010 04:30 PM
Liegekiller
May 30, 2009 05:31 PM
