1970 T350 leak at the slip yoke
Well, I've never seen this. The last 2 times I drove this car, it dumped trans fluid after the drive, while sitting. It is leaking through the slip yoke, not around the yoke indicating a seal. What keeps fluid from slipping past the splines? I going to pull the drive shaft today and do a visual inspection. Any help?
Earlier yokes had a sort of pinhole in the middle of the steel plate at the back of the yoke to allow air to bleed out as the yoke travelled in and out of the back of the trans.
There was a seal a bit forward on the input shaft that rode in a smooth area of the yoke, before the splines started, and no oil was ever supposed to get into the area between the yoke and the end of the shaft, but that's not the way it usually worked out.
Later ones seem not to have it, but have a "missing spline" to allow air out and into the transmission when the yoke is pushed in.
Look at your yoke when it is off - if it has the "missing spline," then you can braze up the hole, grease the splines with a good grease, and all should be good.
edit: See, you answered your own question before I could!
jeffs 89 cutlass salon
October 19th, 2007 08:42 AM
