1957 Jet a way trans how good are they???
Old Jun 5, 2008 | 08:32 AM
Nailhead 88's Avatar
Junior Member
I might have a chance to buy a rebuilt 57 Jet a way trans
The 57 371 sitting in my 50 Olds has the auto flywheel on it, the rear is supported by a chain
will that all bolt up in the 50??? I don't plan to beat the car other then getting on it now and then.
Is this a good way to go, it's a couple hundred for the trans
Old Jun 10, 2008 | 08:33 AM
Junior Member
Tranny length question
Is a 50 Olds Hydramatic and a jet a way the same length, i don't know because i don't have either one
I'm looking for a easy installation if possible
Old Jun 10, 2008 | 10:00 AM
88 coupe's Avatar
Junior Member
Originally Posted by Nailhead 88
........ will that all bolt up in the 50? ........
Use the Jetaway flywheel.
........ Is this a good way to go ........
Yes.
Is a 50 Olds Hydramatic and a jet a way the same length ........
Later trans used a bigger yoke/U joint. Drive shaft modifications are cheap.
Norm
Old Jun 10, 2008 | 12:26 PM
Junior Member
Thanks Norm for the info
442b
Wheels and Tires
Jul 3, 2020 10:02 AM
cutlassefi
Nov 28, 2013 12:08 PM
ATrain1
Non-Olds Engines
Jun 29, 2012 12:58 PM
auto_editor
Jul 10, 2011 11:20 AM
344870M
Aug 21, 2009 08:04 AM
