Toronado Drain Hoses
So the drain hoses on my Toronado was clogged up and one was broken. I know you can get them at Fusicks, but for around $80, I decided just to make my own. Went to a bicycle shop, and the guy had an old inner tube lying there that he just gave me. Really works great. Might get wider ones for next time, but for now, these work fine. I believe you can gete 2.50 width bicycle tires that would fit a bit nicer.
Maybe slightly thicker. But not a whole lot. Not $80 thicker. And the inner tube I have on there is a used one. New one would be better. The old ones were in bad shape. Clogged. Torn. If you just want to keep the water out of your trunk, this works great. Dumped some water in there yesterday to test. Might tear or clog faster than the original ones. But with the amount these cars get driven in the rain, that might be a long time. Im always working towards a budget with my cars. In this case I can get 90% of the effectiveness for 10% of the cost.
Is this for the top drain or sunroof? Interesting setup.
an inner tube would also work for the AC condensate drain on the early 70's cutlass - same looking thing.
ztim
December 22nd, 2006 10:20 PM
