Toronado Drain Hoses
Old Sep 25, 2013 | 06:29 AM
waterzap's Avatar
So the drain hoses on my Toronado was clogged up and one was broken. I know you can get them at Fusicks, but for around $80, I decided just to make my own. Went to a bicycle shop, and the guy had an old inner tube lying there that he just gave me. Really works great. Might get wider ones for next time, but for now, these work fine. I believe you can gete 2.50 width bicycle tires that would fit a bit nicer.
Old Sep 25, 2013 | 08:40 AM
I thought they were supposed to be a solid hose, I would think the tubes would kink?
Old Sep 25, 2013 | 09:20 AM
waterzap's Avatar
The solid hoses are on top. The parts that I replaced are just rubber. About the thickness of inner tubes
Old Sep 25, 2013 | 09:22 AM
Was the original tubing that thin? I know mine on my Cutlass are thick hoses.
Old Sep 25, 2013 | 09:33 AM
waterzap's Avatar
Maybe slightly thicker. But not a whole lot. Not $80 thicker. And the inner tube I have on there is a used one. New one would be better. The old ones were in bad shape. Clogged. Torn. If you just want to keep the water out of your trunk, this works great. Dumped some water in there yesterday to test. Might tear or clog faster than the original ones. But with the amount these cars get driven in the rain, that might be a long time. Im always working towards a budget with my cars. In this case I can get 90% of the effectiveness for 10% of the cost.
Old Sep 25, 2013 | 07:15 PM
Lady72nRob71's Avatar
An old tube is most likely better because they are often thicker. The last new tube i got was as thin as a condom.
Is this for the top drain or sunroof? Interesting setup.
an inner tube would also work for the AC condensate drain on the early 70's cutlass - same looking thing.
Old Sep 25, 2013 | 07:47 PM
501Paratrooper's Avatar
There are "thorn" tubes that are super thick try those.
Old Sep 26, 2013 | 07:37 AM
waterzap's Avatar
Thorn tubes? That might work.
ydennekkram
Sep 25, 2013 09:36 AM
SJL
Body work
May 14, 2013 04:20 AM
a6m5zerosen
Jan 11, 2008 08:29 PM
prawnman88
Apr 27, 2007 07:54 PM
ztim
Dec 22, 2006 10:20 PM
