Selling a bunch of 66-67 Toronado parts
Old July 16th, 2014, 05:00 PM
my67toro's Avatar
Hello,
I have had some parts laying around for a while and I though that I should put them up for sale. They have been on eBay for a few weeks now. Here are the links to the items. On some of the bigger parts, if you send me a legitimate offer, I will consider it! I just want these parts gone!
All an old parts are from a parts car that I had.
Right Front Door Center Trim Finishing: http://www.ebay.com/itm/291199038297...84.m1555.l2649
Left Front Door Center Trim Finishing: http://www.ebay.com/itm/291199038241...84.m1555.l2649
Right Front Door Trim Pad Moulding: http://www.ebay.com/itm/291199038196...84.m1555.l2649
Left Front Door Trim Pad Moulding: http://www.ebay.com/itm/291199038104...84.m1555.l2649
Bezel Cluster (Without Gauges): http://www.ebay.com/itm/291199037983...84.m1555.l2649
Transistor AM PB Radio (Without Fade): http://www.ebay.com/itm/291199037551...84.m1555.l2649
Left Door Trim Reflector (No Light): http://www.ebay.com/itm/291199035766...84.m1555.l2649
Right Door Trim Reflector (No Light): http://www.ebay.com/itm/291199036014...84.m1555.l2649
Left Arm Rest Cover-Clip (Manual Windows): http://www.ebay.com/itm/291199036372...84.m1555.l2649
Right Arm Rest Cover-Clip (Power Windows): http://www.ebay.com/itm/291199037042...84.m1555.l2649
Right Door Handle: http://www.ebay.com/itm/291199037396...84.m1555.l2649
Back Left Cigarette, Lighter: http://www.ebay.com/itm/291199037465...84.m1555.l2649
Rear Seat Speaker Grille: http://www.ebay.com/itm/291199036501...84.m1555.l2649
Glove Box: http://www.ebay.com/itm/291199035379...84.m1555.l2649
my67toro is offline
Old January 9th, 2015, 12:32 PM
tarzangui's Avatar
Hi, Do you have a carburetor from one of the cars for sale?
tarzangui is offline
Old January 9th, 2015, 02:15 PM
my67toro's Avatar
Sorry, but I do not. My original one broke and I ended up replacing it with a new Edelbrock one. Gave me better performance, and batter MPG!
my67toro is offline
Old January 9th, 2015, 09:12 PM
tarzangui's Avatar
I have a 1966 Toronado. Which edelbrock carb did you use for your Toronado? I was told it would sit too high for the air filter/snorkel. Also the linkages would be off. I'm having a hard time finding a Rochester replacement. Could you give me more info on your situation. Thanks Kevin
Old January 9th, 2015, 09:58 PM
my67toro's Avatar
Yeah, I can tell you that it didn't go without modifications and a couple problems. The Edelbrock I ended up putting in was Edelbrock 1411. Problem with the Edelbrock is you need that inch spacer between the motor and the carburetor , which unfortunately raises it. I also used the rod that is in the middle of the carburetor to put the wing nut on from the old rochester and it happened to be too tall, so I cut it down and re-threaded it. unfortunately once the air cleaner is on, I have maybe 3-5 thread left to get the wing nut on, but it secures it well!
The other problem I encountered is that the Edelbrock is too wide and when you try to fir the factory air cleaner on, it will not fit on one side. So I cut out a little whole in the air cleaner to allow it to fir on properly. Whether this was a good or bad idea is up for debate, but I just needed to be done at that point.
Also, you cannot slam the hood down, because there is literally like 1/4 inch or so of clearance between the air cleaner and the hood. Unfortunately, when I took my car in to get the transmission serviced, some dumbass slammed the hood down and now I have a nice circle popping out in the middle of my hood that needs to be hammered back down.
So yes, there is a lot of work and problems that goes into getting that Rochester to work. Whether it is worth your time, I don't know, but at least you know what to expect and some pointers to keep you from making my same mistakes.
Hopes this helped you!
my67toro is offline
Old January 29th, 2015, 09:00 AM
ActionMan84's Avatar
Smile 1967 Toronado
Im and doing a frame off restoration on a 67 toronado, if anyone has spare parts they would like to sell please email me. I am looking for the rear vent panel between the back glass and trunk, some wheel trim, fender well trim, and other smaller misc item. randyjr@actionautoservices.com
ActionMan84 is offline
Old January 29th, 2015, 09:24 AM
my67toro's Avatar
I still have these if you need them, nothing else unfortunately:
Right Door Trim Reflector (No Light): http://www.ebay.com/itm/291353031092...84.m1562.l2649
Right Arm Rest Cover-Clip (Power Windows): http://www.ebay.com/itm/291353031094...84.m1562.l2649
Right Door Handle: http://www.ebay.com/itm/291353031093...84.m1562.l2649
Back Left Cigarette, Lighter: http://www.ebay.com/itm/291353031091...84.m1562.l2649
Glove Box: http://www.ebay.com/itm/291353031097...84.m1562.l2649
my67toro is offline
Old January 29th, 2015, 11:25 AM
chazz83's Avatar
actuator
do you have a headlight assembly for sale right side
chazz83 is offline
Old January 30th, 2015, 07:05 AM
lmetcalf's Avatar
I have a right side headlight assy for a 66, if you're interested.
lmetcalf is offline
Old January 30th, 2015, 07:08 AM
lmetcalf's Avatar
I have a Rochester carb from a 66 Toronado, if interested.
lmetcalf is offline
Old January 30th, 2015, 08:55 PM
chazz83's Avatar
headlight
I have a 67 olds tornado..i think the actuators are different..
chazz83 is offline
Old April 23rd, 2015, 02:44 PM
rocketlover
ed burke's Avatar
toronado
Hi, I need an accelerator pedal.
ED
ed burke is offline
Old April 25th, 2015, 06:06 AM
rocketlover
ed burke's Avatar
accelerator pedal
Hi, Did you get my reply
ED
ed burke is offline
JCMC64
February 2nd, 2019 10:22 AM
JCMC64
May 23rd, 2016 10:24 PM
angelica
September 29th, 2012 07:06 PM
69Rman
January 9th, 2010 10:04 AM
Quick Reply: Selling a bunch of 66-67 Toronado parts
