question about keys ('69)
The '69 I bought has no keys, previous owner cannot find them.
Are the doors & ignition the same key? It'd be a little easier to pop the door lock cylinder out.
Thanks!
Thanks!
The doors and ignition should be the same (square "E" key , and the glove box and trunk should be the same (round "H" key). If you can get one of the door lock cylinders out, the key code will be stamped on the cylinder. The same goes for the glove box cylinder. A good locksmith can make you new keys based on those codes. Hopefully, the ignition cylinder and the trunk cylinder haven't been changed and you will be back in business.
The guy remembered the set of keys said GM on them, so I'm pretty sure they are the original locks.
Glad to hear they are the same, I can get that cylinder out in a jiffy.
Thanks guys!
Thanks guys!
