question about keys ('69)
Old May 25, 2010 | 12:31 PM
wikkonado's Avatar
The '69 I bought has no keys, previous owner cannot find them.
Are the doors & ignition the same key? It'd be a little easier to pop the door lock cylinder out.
Thanks!
Old May 25, 2010 | 06:22 PM
66400's Avatar
Doors and ignition were matched whrn it left the factory, so if it hasn't been changed out..............
Henry
Old May 25, 2010 | 06:48 PM
rcorrigan5's Avatar
Randy C.
The doors and ignition should be the same (square "E" key , and the glove box and trunk should be the same (round "H" key). If you can get one of the door lock cylinders out, the key code will be stamped on the cylinder. The same goes for the glove box cylinder. A good locksmith can make you new keys based on those codes. Hopefully, the ignition cylinder and the trunk cylinder haven't been changed and you will be back in business.
Old May 25, 2010 | 06:54 PM
wikkonado's Avatar
The guy remembered the set of keys said GM on them, so I'm pretty sure they are the original locks.
Glad to hear they are the same, I can get that cylinder out in a jiffy.
Thanks guys!
Garbled
Mar 24, 2015 10:46 AM
meanmechanic01
Aug 2, 2012 10:51 AM
old blue
Aug 18, 2009 02:22 PM
Snowdog
Apr 14, 2009 03:51 PM
Vesuvian
Sep 14, 2004 06:32 AM
