Edelbrock carb on 70 Toro
Old Jan 29, 2012 | 09:29 PM
sgtoro's Avatar
Has anyone used an Edelbrock carburetor on the stock intake on a 66-70 Toronado? If so, any issues encountered?
Old Jan 30, 2012 | 06:47 AM
TripDeuces's Avatar
You'll need an adapter so the carb will be higher. Do you have the room? I know my 70 was tight for hood clearance but it's been a long time since then and I don't remember how much room there was. Edelbrocks might be wider also with a side fuel inlet so will it fit under the stock air cleaner or are you changing that also?
Old Jan 30, 2012 | 09:17 AM
sgtoro's Avatar
What kind of adapter would I need? I don't think the orig. air cleaner would be that much of an issue, I have a chrome one I can use.
Old Jan 30, 2012 | 09:27 AM
TripDeuces's Avatar
Are you talking an Edelbrock Q-Jet or the Carter AVS style? The Q-Jet would need no adapter but the other would as it's a square bore carb. The Toro air cleaner is a drop down base type. It hangs low so there may be interference. If your chrome air cleaner has a drop down base then you should be fine.
Old Jan 30, 2012 | 09:41 AM
VikingBlue's Avatar
All I know is, you best paint your car the original Oxford Gray.
Old Jan 30, 2012 | 06:37 PM
copper128's Avatar
Lt. Buzzkill (ret.)
I'd recommend you consider this instead of the Edelbrock (Carter AFB). Bolt it right on in place of the Q-jet, no adapters needed and the added bonus of an electric choke.
http://www.jegs.com/i/Holley/510/0-80555C/10002/-1
Old Jan 30, 2012 | 07:45 PM
Rickman48's Avatar
X2 on that one!
Old Jan 31, 2012 | 02:18 PM
EightballZ's Avatar
nothin beats a well tuned qjet...
69CutlassAlex
Jul 30, 2013 08:18 AM
vistacruiser1971
Dec 27, 2012 07:35 AM
70Cutlass_408
Jun 24, 2011 07:55 AM
fearthisrocket
Feb 18, 2008 06:19 AM
Huron
Jul 9, 2007 11:56 AM
