Core Plug ("Freeze Plug") Fun 🤬
Old Feb 28, 2024 | 09:17 PM
mike 66 toro's Avatar
Hi all! It's been a while - multiple concurrent toys I've been working on.
This is being very very stubborn. Ideas? I removed the starter for good access.
Old Feb 28, 2024 | 09:39 PM
Charlie Jones's Avatar
Phantom Phixer
The good news is you will fix one plug.
The bad news is the other 5 are in similar condition.
Old Feb 29, 2024 | 04:40 AM
Since you gouged out the bad freeze plug you have to decide if you're going to replace it lying on your back under the car, or if you're going to remove the engine. If you decide to remove the engine you MAW replace all the freeze plugs and do other maintenance that might be needed. What's the condition of your oil pan and timing chain cover gaskets?
Old Feb 29, 2024 | 06:15 AM
I am focused on this one plug for now. I was not expecting it to be this stuck. I've pried quite a bit, even bending a 3/8 ratchet extension in the process.
Any ideas how to get this thing out?
Old Feb 29, 2024 | 06:29 AM
Generally you'd aligned a punch on the "edge" of the plug and smack it w/ a BFH. The plug should rotate inside the hole. Of course, tons easier w/ engine removed.
Old Feb 29, 2024 | 07:13 AM
Yeah I had hoped to smack it hard enough to get it to move. The approach is a little bit angled. I also figured prying it would help. It's still firmly in place. Now I'm thinking in terms of chemicals and fire.
Old Feb 29, 2024 | 07:34 AM
Phantom Phixer
If you have a channel lock pliers, you may be able to get the tip in there and wedge it out.
You can get an expandable rubber freeze plug at an auto parts store.
That will be much easier to install lying under the car.
That will make a great temporary repair until the other 5 plugs start leaking.
Old Feb 29, 2024 | 08:54 AM
Finally, success. This morning it decided to cooperate for some reason.
Old Feb 29, 2024 | 12:35 PM
You have any knuckles left?
Old Mar 1, 2024 | 05:21 AM
tonymueller55@gmail.com's Avatar
Looks great, good job!
How about you replace mine for me now?
Old Mar 9, 2024 | 06:44 PM
None
See above.
Old Mar 25, 2024 | 02:11 PM
pmenyhart's Avatar
freeze plug tool
The OP got it done--good job.Here is advice for others.Buy a freeze plug installation tool.There are plenty on the web I'm sure Harborfreight has them used this in my shop for many years and it makes it soo much easier.Of course I have the benefit of a lift.I could't do anything with my 73 year old screwed up body..
I'll try to put a link:
link didn't work--google freeze plug tool
Old Mar 25, 2024 | 05:54 PM
307-5a's Avatar
Roy Ale
I had the same issue with my engine on a road trip when i first picked up my car , same frost plug behind starter , frost plug was rusty and dumped the coolant . For a quick fix had a shop install a block heater , that plugged the hole until i could get the car home . Then had a local shop replace all the frost plugs except one , they were not able to do the frost plug behind the dip stick tube , with out breaking the dip stick tube so that plug still needs done .
As Charlie said the others will go next , so one done but more to go .
Question is this issue do to acidic coolant ? or would happen any way ?
2nd question is there another frost plug between the engine and trans that could corrode and leak coolant ?
Old Mar 25, 2024 | 06:46 PM
Phantom Phixer
I don't know if it is an acidity issue, but the failure to change coolant regularly ( flush & fill ) causes most cooling system rust problems.
In some localities the water is acidic, and it is recommended that distilled water and antifreeze mixture should be used.
#2,Yes sometimes there are, as well as plugs in the cylinder heads.
friesjh
May 26, 2022 04:43 PM
rcwjr
Nov 16, 2021 10:17 AM
sammicurr86
Sep 5, 2021 08:05 PM
Jan 27, 2021 04:29 PM
Steven Hall
Mar 22, 2019 08:33 PM
