67 Toronado Motor Mounts
Old Aug 1, 2014 | 08:25 AM
waterzap's Avatar
Looking to take out and rebuild engine on Toronado later on. While it is out, it might be a good idea to get new motor and transmission mounts. I see Fusicks does not have them, but Rock Auto does. Any idea if they are in fact the correct ones that will fit?
Old Aug 4, 2014 | 09:59 AM
Not even close. The motor mounts that RockAuto shows are the 2262 and 2263 mounts, which fit the 1965-1970 Olds D88 and Ninety Eight. They DO NOT fit a Toro. The Toro uses a single front mount under the harmonic balancer and a pair of mounts on either side of the rear of the trans.
By the way, the transmission mount they list is also incorrect - it's for a RWD car. Of course, this is the same company that also lists a manual trans clutch kit for a Toronado...
If Fusick doesn't have the mounts, your only choice is to have your old ones revulcanized by Steele Rubber.
Old Aug 4, 2014 | 10:08 AM
waterzap's Avatar
$75 per mount....
Old Aug 4, 2014 | 10:20 AM
$75 per mount....
There's a big difference in the labor involved in mass producing tens of thousands of an item and doing a one-off job. $75 is less than I would have suspected. Keep in mind that they have to clean the old mounts, fabricate a mold for the rubber, THEN vulcanize the parts back together.
Old Aug 4, 2014 | 10:35 AM
waterzap's Avatar
Some of the mounts there are $500. The Toronado mounts must be easier to refurbish. I don’t think I NEED new mounths, but seeing I am going to pull the engine. Prob best to just do it and get it done. If I ever have to have the transmission rebuilt. Do they have to remove the engine too, or can they pull it from the bottom?
The_Jeremiah
May 16, 2019 03:19 PM
joesw31
May 31, 2015 04:17 PM
Nasty455
Mar 20, 2012 04:57 PM
ctrain22
May 20, 2009 11:02 PM
flatoz
Mar 15, 2009 02:03 PM
