66 toro tilt/tele steering column
Was the 66 toro column used in any other cars that year or any year? I have one, like most of them with turn signal issues. The turn signal actuater is broken and I either neeed to replace it or the whole column.
Help!!!
Help!!!
I think it's the same until 69, and Eldorado probably as well, HOWEVER there are several variables:
Tilt? yes
Cornering lights?
Cruise? (may not have been avail)
Someone wiser will come along, but check here: http://www.toronado.org/
and search the site
Tilt? yes
Cornering lights?
and search the site
Nice thought but i found mine in too many peices when I opened the column. There is bound to be a source that the rebuilders use but getting them to release it... Now there's the challenge.
Is it a Boyne switch or Guide?? PN 1993597 65-66 all w/ tilt but not cornering olamps: PN 911051 65-66 all W/O tilt or cornering lamps, W Guide lamp housings: PN 1993667, 66 All W/tilt and cornering lamps: PN 910813, 66 All W/ cornering lamps except tilt: Try that...
overwhelming indeed
I'm not even to trying to locate a switch yet. Actually the column is installed in a custom stepside chevy truck I took on to restore. I also have a 06 Corvette. I've been a member of Corvette forum for several years now and I knew when it came to Olsmobile products, you guys have already been in the trenches and would have the answers. I hope you don't think me to be an imposter and I appretiate the help I have gotten so far.
I'll have to check with my body man. I was out of town when it arrived and it was taken straight to him before I saw it. I do know that it came without a steering wheel so that leads me to believe that it probably didn't have a center cap also but I'll check.
