66 Toro gas pedal mounting
Old Nov 12, 2020 | 03:25 PM
sgolds's Avatar
I have a 66 Toro that is having the drivers floor under the gas pedal repaired, I have the gas pedal and it has a square bracket attached to the bottom that kind of swivels. How exactly does the gas pedal mount to the floor? That bracket Seems to be the only place the pedal would be mounted to the floor, or is the pedal attached to the throttle linkage at all? Pics would be greatly appreciated thank you!
Old Nov 14, 2020 | 07:02 AM
Bill's Auto Works's Avatar
Hello Sir,
Mine is a 67 but I am pretty sure the gas pedals are the same. I am just finishing up a complete restoration of a 64 Grand Prix & it has the same pedal set up!
The pedal does NOT attach to the linkage, it just sits against it. You pedal should have two hole in the rubber on the bottom. These two holes push onto steel "*****" on studs sticking out of the floor. I have never removed one of these studs but I am sure they are threaded in a welded nut.
Here are a couple of pics, not very good pics because of the location & trying to hold a drop cord for light! LOL If you need anything else feel free to ask! My floor will be completely bare today so I can put down the FatMat.
God bless
Bill Squires(owner)
Bill's Auto Works
https://www.jalopyjournal.com/forum/...closed.614419/
Old Nov 14, 2020 | 03:47 PM
sgolds's Avatar
Bill's, thanks for the info and pics. My gas pedal is attached to a rectangular bracket at the bottom that swivels, maybe it was part of the floor. Those studs appear to be at the bottom of the bracket I think. I will have to post pics here if I can. Doesn't look anything like the one in the pic's you posted.
Can the pedal mount from another car such as that GP you mentioned be used here? Also, what other cars share the same design? Hopefully an Impala so that I can find parts more easily!
Old Nov 14, 2020 | 03:54 PM
Honestly I am not sure!
I only mentioned my 64 GP because my Toro was a 67 & I thought since it was newer than yours & the GP was older than yours, they would be the same as yours
Best of luck!
God Bless
Bill
Old Nov 14, 2020 | 04:16 PM
sgolds's Avatar
Here's a pic of the pedal, I know it's a bit hard to see, I have to take more pictures. You can see it has a bracket attached to the bottom that swivels back and forth. It appears to have studs on the bottom, but I have to check again.
Old Nov 14, 2020 | 04:31 PM
Yes, we need to see a close up picture of it. Is it possible the "Bracket" you are speaking of is just a part of the floor that is no longer attached because of the rust out? The piece on the floor of mine could possibly be a separate piece that is welded to the floor pan, I never looked that close.
Old Nov 14, 2020 | 05:36 PM
sgolds's Avatar
That's what I was thinking. Here are some more pics that show more detail.
Old Nov 14, 2020 | 05:38 PM
sgolds's Avatar
Old Nov 14, 2020 | 05:46 PM
Yes! That is the same as mine. The studs have ***** on the end of them & are in the holes in the rubber, just pry them out. After you fix the rotted floor, fabricate another piece with welded nuts. You can probably find somebody with a car they are scrapping that have the studs.
Old Nov 14, 2020 | 06:02 PM
sgolds's Avatar
Ok thanks, nice to know that mine wasn't jerry rigged in some way. Can I use the current bracket in some way? I think the mount might be different on my "rubber and chrome floor mat" thingy than if it was just a carpet there, not sure though .
Old Nov 14, 2020 | 06:11 PM
No, there is nothing usable there except for the pedal itself! Do Not Reuse that rusty piece of metal. Mine also had the same floor mat as you are describing. I destroyed it taking it out because it was so brittle. I will not be putting one back in, just carpet & normal floor mats.
Old Nov 14, 2020 | 08:00 PM
sgolds's Avatar
I'm guessing that the mount attaches in the little circle cutout in the rubber mat? That's where the hole in the floor is, right in that spot
Old Nov 14, 2020 | 08:01 PM
sgolds's Avatar
Also, are the studs that attach to the floor and go into the gas pedal the same as an Impala, etc.?
Old Nov 15, 2020 | 03:51 AM
Yes, that is where it sits on the floor! I have no idea whether the Impala is the same or not. I would guess yes, because I think the factory would limit cost by only making one size, but again just a guess. At the point you are at I would just measure from the top of the ball to the bottom of the thread & also the ball diameter & go from there!!!
God Bless & Happy Thanksgiving
Old Nov 15, 2020 | 04:44 PM
I happen to see these on Ebay!
https://www.ebay.com/itm/58-70-GM-Ga....c100005.m1851
Call inline tube, I have dealt with them before ...good people! They have your studs
Old Nov 16, 2020 | 01:05 PM
sgolds's Avatar
Thanks for the link. If I left off that bracket would the pedal end up too close to the floor? Also, how do you remove the studs from the pedal?
Old Nov 16, 2020 | 01:18 PM
The ball ends of the studs are just pushed into the pedal, pry them out! The rubber is probably hard, so it might take some muscle. The piece of metal that you are calling a bracket is just (for a better word) a block of metal. It would be much simpler to work with another thick piece of metal on the workbench IE: drilling & tapping for the studs, then weld it in place. I personally would not just put the studs in the floor, but I have been fabricating/customizing & restoring for decades , so this is a easy fix compared to others.
Old Nov 17, 2020 | 03:47 PM
sgolds's Avatar
Speaking of the drivers floor, is it the same as the 66 Riviera? I noticed that there is a replacement drivers floor available for the Riv, but not for the Toronado.
Old Nov 17, 2020 | 03:53 PM
Someone else with more specified knowledge will have to help you with that one! I only ever had a 68 & an 84 Riv, but both were clean Southern cars. Never paid any attention to the floor.
Old Nov 17, 2020 | 04:07 PM
sgolds's Avatar
Got it, thx. for your help with the gas pedal! I will start another thread on that question.
Old Nov 18, 2020 | 02:21 PM
torotoyguy's Avatar
Per ad in newsletter from Toronado and Aurora Chapter of Olds Club of America, there is a complete floor pan kit available from Gary Wachtell at Antique &Classic Restoration Co., 502 Cranlyn Court, Brunswick, OH 44212, 330-273-3784. Maybe this helps.
Old Nov 18, 2020 | 04:55 PM
sgolds's Avatar
Cool, thanks
R8der4life
Jun 4, 2013 06:51 PM
vista cruiser 1
Sep 2, 2012 04:50 PM
vista cruiser 1
Sep 2, 2012 03:39 PM
66ninetyeightls
Ninety-Eight
17
Sep 1, 2011 01:17 PM
TripDeuces
Sep 9, 2010 04:49 AM
