Accelerator Pedal keeps falling off.
Just wondering if anyone has ever replaced the factory accelerator pedal on a full sized car with something else?
The two small studs that come out of the floor are rusted pretty good so they may now be a bit to small. The part on the pedal assembly that they pop into is also cracked.
So now unless I am extremely carful while driving my accelerator pedal falls off and I am left with pushing on the actual linkage with my foot. It is becoming very tiresome.
I doubt the ball studs have eroded away that much. It's more likely the crack in the pedal. Same thing happened to me on my 66 Cutlass. I purchased a pedal and two studs from The Parts Place. I didn't even use the studs as they were fine and the pedal looks and works great. I'm not sure how a Cutlass pedal and a 98 compare but it's worth taking a look.
http://www.thepartsplaceinc.com/ocat...&YearList=1966
Craig, the Cutlass pedal is about 2/3 the size of a full size pedal. Someone else had this problem and I was going to try and dig out some pedals I've pulled over the years that I though were still good. If I find more than one you can have the second best as the other member asked first. John
Your the best John! Thanks very much.
So John were you able to find any?
Gas Pedal
Hi Craig,
I still have a nice one you can have if you're still in need. The holes that fit over the floor mounting studs are 100% perfect and the face of the pedal is almost in "as new" condition.
I hear that... it's tough accelerating smoothly without the pedal. Last time I knocked mine off I was on a steep hill in SF, in stop and go traffic... not fun! I recently picked up a used pedal from a member here. It's nice not to have to deal with that anymore. Good luck, hope you find one, too.
stocki26
Ninety-Eight
15
August 29th, 2014 06:17 AM
