1966 Toronado HEI swap
Old Jun 22, 2014 | 05:55 PM
AMREITES's Avatar
Car is starting to come together drove it around the block to day NO MORE POINTS runs alot better with this set up.
Old Jul 22, 2014 | 08:12 AM
waterzap's Avatar
How did you fit the HEI distributor behind the air filter? Looks smaller than mine
Old Jul 22, 2014 | 09:42 AM
TripDeuces's Avatar
"How did you fit the HEI distributor behind the air filter?"
It's not an OEM HEI. It's a MSD unit which uses the same size distributor cap as stock
Old Jul 23, 2014 | 08:53 AM
Just so we're all clear, HEI (High Energy Ignition) is GM's term for the coil-in-cap distributor. People incorrectly use this term to refer to all electronic ignitions, which is like my grandmother calling all refrigerators "frigidaires".
Old Aug 10, 2014 | 10:06 PM
steve walker's Avatar
swat455
its a pro comp dist from speedmaster how do you like it. as I just got one on ebay
Old Aug 11, 2014 | 10:56 AM
AMREITES's Avatar
It was easy to install, had to make my own bracket to hold the coil but so far i like this set up.
QuinnKnight
Nov 7, 2019 05:19 PM
joepenoso
Jun 4, 2014 01:56 PM
radioburningchrome
Dec 11, 2013 05:22 PM
'69CutlassVert'
Aug 25, 2011 07:19 AM
oldscruiser
Feb 15, 2011 12:44 AM
