1966 toronado headlight actuator
Old Oct 5, 2013 | 05:56 PM
AMREITES's Avatar
Hi has anyone ever used a early 1970 corvette headlight actuator on a 1966 toronado to replace the canisters looks like it would work? Any thoughts?
Old Oct 6, 2013 | 03:39 AM
TheBirds's Avatar
After having my canisters rebuilt (still in box) I went online and bought a set of 12V DC linear actuators. They work well.
I chose a set that can lift 50lbs and has a static hold of 500lbs (so the lights wouldn't bob up and down when driving at night).
They take 7-8 seconds to lift and drop. I don't know how that compares to the vacuum originals because mine were broken when I got the car.
I have to do some final wiring but the switch is under the dash (out of sight) below the headlight ****.
Lots of manufacturers make them I just chose a set of "weatherproof" ones so they work in all conditions. They were around $250 for the set.
Try this link if interested:
http://www.firgelliauto.com/linear-a...rs-catalog.php
Jeff
Old Oct 9, 2013 | 08:05 AM
waterzap's Avatar
Any photos of your setup?
Old Oct 10, 2013 | 08:15 PM
TheBirds's Avatar
I can try to take some pics but access is pretty limited. If I can get some decent pics I'll post them over the weekend.
J
Old Oct 16, 2013 | 02:03 PM
TheBirds's Avatar
Linear actuators
Here are the best pics I could get of the actuators in place.The first three are the passenger side. The last one shows the vacuum box and the actuator. Sorry, best I could do.
Jeff
Old Oct 17, 2013 | 07:45 AM
waterzap's Avatar
What did you use to connect them to the headlights and the body? Did you have to create any new clamps?
Old Oct 26, 2013 | 07:51 PM
TheBirds's Avatar
The linear actuators came with a set of brackets to weld onto the existing hardware. I don't know if all the manufacturers of the linear actuators include the mounting brackets or if you have to make your own with some manufacturers. The original brackets are still usable with a little grinding.
No too difficult.
Jeff
bomberman89
Oct 21, 2015 02:27 AM
waterzap
Aug 15, 2013 08:39 AM
clinton70
Jan 24, 2010 04:20 PM
elcaminodave
Oct 28, 2008 05:52 AM
ProudToBeOlds
Jun 12, 2008 10:46 PM
