1966 toronado headlight actuator
After having my canisters rebuilt (still in box) I went online and bought a set of 12V DC linear actuators. They work well.
I chose a set that can lift 50lbs and has a static hold of 500lbs (so the lights wouldn't bob up and down when driving at night).
They take 7-8 seconds to lift and drop. I don't know how that compares to the vacuum originals because mine were broken when I got the car.
I have to do some final wiring but the switch is under the dash (out of sight) below the headlight ****.
Lots of manufacturers make them I just chose a set of "weatherproof" ones so they work in all conditions. They were around $250 for the set.
Try this link if interested:
http://www.firgelliauto.com/linear-a...rs-catalog.php
Jeff
Jeff
The linear actuators came with a set of brackets to weld onto the existing hardware. I don't know if all the manufacturers of the linear actuators include the mounting brackets or if you have to make your own with some manufacturers. The original brackets are still usable with a little grinding.
No too difficult.
Jeff
No too difficult.
Jeff
bomberman89
Oct 21, 2015 02:27 AM
