1966 Toro Tele Tilt Acutator vs Edlo Actuator
Old Mar 26, 2022 | 07:30 PM
BlackBirdPilot's Avatar
Working on the tele tilt system, while waiting on a replacement actuator. I decided to try to repair my broken unit. While I was able to glue the actustor back together faily tighy (such that when i put pressure on the metal beacket, the whole actuator flexes with it comming apart at the original break)
Attemping to reinstall the unit, eveyrthung seems to work right, up until i try to mount the switch back onto the mast jacket in the original location. Its seems like the cable is a 1/2" to short and pulling on the casing untimately breaks the repair. Im windering if at some point the unit wasnt swaped out for a unit sourced frim an Eldo at one time in its like. Either that or the bowden cable housing has shrunk over the last 55 years.
Does anyone know the measurements if the cable assemblies?
Old Mar 27, 2022 | 06:02 AM
dbater's Avatar
Check with Chuck Shuster musclecarman1969@hotmail.com if anyone would know it will be him.
Dave’s Holiday 55
Aug 20, 2021 09:19 AM
parkside
Dec 18, 2020 10:12 PM
76olds
Aug 11, 2016 12:24 PM
JohnnyBs68S
Brakes/Hydraulic Systems
15
Sep 2, 2015 02:16 PM
carl 87 cutlass
Sep 7, 2012 06:51 PM
