1966 oldsmobile toronado gas tank?
Old Jan 2, 2008 | 05:55 PM
komondu's Avatar
OldsRocket
just like the title says. im in need of one and the sending unit if someone knows or has one let me know.
thanks
I also have problems with the vacuum headlights? How can I tell if the whole mechanism still works? Right know it wont turn up when switch is activated.
Old Jan 3, 2008 | 06:41 AM
Those pneumatic headlights fail often. I think you can get parts for them at Fusicks. You might also be able to find a gas tank there, or at least a gas tank rebuilding kit (with the coating and cleaner).
http://www.fusick.com/
Old Jan 3, 2008 | 08:22 AM
2blu442's Avatar
Toro Lights
I'm dismantling a couple Toro's and when I get to the tank I could pull the sending unit. I don't think I could ship a used tank as it would be considered a hazardous materials item. I have a vacuum gun designed for bleeding the brakes that I put on the hoses to test the trunk release. You could use one to try and open/close the headlight doors and trace the system between the lights and the switch. Find the place where the vacuum stops working. John
joemo
Sep 21, 2022 04:47 AM
69ToroCustom
Dec 13, 2015 05:20 PM
wikkonado
Dec 13, 2015 06:21 AM
1carsick
Oct 17, 2012 09:10 AM
Texas442
Jan 30, 2012 05:36 PM
