alternator failing within 2 miles of install
1968 cutlass S 350 automatic - p/s - no a/c
The rebuilt alternator that has been on the engine since 2019 failed.
This failure happened after replacing a defective battery with a new one.
I just got a replacement ( carquest rebuilt 7122a ) and installed it.
It failed in 2 miles.
The alternator got too hot to hold at the back end ( away from the pulley )
I am at a loss as to what to do or check next.
Please help with some suggestions.
Thank you in advance for your assistance.
Bill
Bill
Alternators can get very hot. Were there any other symptoms, is it charging and was the battery fully charged before installing the alternator? The alternator may have been producing high amperage to charge a weak battery.
Voltage
fully charged battery before both alternator failures
Have the parts store test the alternator before you leave the store. That way you will know for sure if it's working properly before you install it in your vehicle. Do not assume that a new part works as it's supposed to.
Bill,
There was a thread the other day on one of the professional auto repair forums I belong to. Guy was working on a fairly late model For truck and went through 5 reman alternators that would not work right out of the box. Went and got a new one from Ford and it was fixed
So dont be a bit surprised if it isnt just the junk parts available now days,
I put in a new voltage regulator. Seems the issue has been resolved. Time will tell.
The old regulator has a removable cover. There are what seems to be 2 adjusting screws, One is a black know at the top. The other is an adjusting screw that handles the spring tension for one of the contact points.
Is there a procedure to adjust these screws? Not that it is needed, but I am very curious.
Thanks again.
Hopefully back on the road for a long ride tomorrow.
Thanks again.
