Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
V8 Intake Manifold Lift Bracket Washers
Old Jun 23, 2014 | 12:07 PM
Rocketguy's Avatar
Hello Joe,
I am working on a '71 W-30. I have seen these engine lift brackets installed three ways.
One is with no washers on the bolts. This page from the engine assembly manual clearly states the requirement of 12 washers:
This pic I found on the web has them between the bolt and bracket (I know it is a '67 but I have seen them between the bolt & bracket '71 cars too):
The Inlinetube guys have theirs under the bracket (this is a '72 but. . . );
Can you tell me which is correct?
Thank you.
Old Jun 23, 2014 | 12:28 PM
jensenracing77's Avatar
On aluminum intakes, Washers under the bracket. Iron manifolds, No washers.
Old Jun 23, 2014 | 02:15 PM
BlackGold's Avatar
That's the problem with the '71 Engine Assembly Manual; it doesn't have lots of pretty pictures.
Look at the '70 manual instead. Page 16 shows a pretty picture and describes the washer usage.
Old Jun 23, 2014 | 03:58 PM
Rocketguy's Avatar
Both very useful responses, thank you so much, I appreciate it blackgold and jensenracing. It is page 19.
Old Jun 23, 2014 | 04:29 PM
Octania's Avatar
I thought the tube/ wiring holder tabs on the rocker cover went the other way 'round. With tube clips upward.
Old Jun 23, 2014 | 04:39 PM
costpenn's Avatar
Looks great!
Old Jun 23, 2014 | 04:58 PM
Rocketguy's Avatar
Not with OAI; I assume it was so the retaining spring for the OAI top could be easily secured/removed.
bobb
Nov 11, 2010 08:26 PM
Ddbord
May 28, 2010 07:47 PM
nelsontj
May 5, 2010 05:30 AM
jensenracing77
May 1, 2009 02:35 PM
