Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
Timing by Vacuum? Is This a Thing?
Old Jul 23, 2017 | 10:52 AM
Hey, all.
For some time I've been fiddling around trying to get a proper timing curve in my '69 400G. Now I've heard from a couple of sources, (my mechanic who works on my newer vehicles, as well as an article posted here on CO) that there's no need to mess around with a timing light, all you need to do is adjust the distributor for maximum vacuum reading, more or less the same way you adjust idle mixture. Easy-peasey.
It seems a little TOO easy-peasey to me. Opinions?
Old Jul 23, 2017 | 01:49 PM
It does work on relatively stock engines and will normally get you in the ball park. I use it on old cars where the timing mark is on the flywheel and can't be read. Disconnect and plug vacuum advance. Set your idle speed as low as you can get it and still have a smooth idle. Advance timing until you get the highest vacuum on the gauge while readjusting idle speed back down to maintain minimum rpm's. Once you get the highest vacuum retard the timing until the vacuum gauge reads 2" less than the highest vacuum reading and tighten the distributor lock down bolt. Then adjust the a/f mixture screws on the carb for the highest vacuum and readjust idle for your normal idle speed.
Personally it is not a widely acceptable method and if it were the auto manufacturers would have it in the CSM or tuneup specs. It's a lot more accurate to use a timing light and always repeatable.
Old Jul 23, 2017 | 06:17 PM
Still, that's a good synopsis you gave, so I may give it a shot. Couldn't hurt to try. Thanks.
Old Jul 23, 2017 | 06:41 PM
If you experiment, see what it ends up being with a timing light.
Old Jul 23, 2017 | 07:46 PM
That's what I plan to do -- set it using the vacuum method and see what it shows with the light.
Old Jul 24, 2017 | 09:20 AM
That's a cool trick. I never heard of it before.
jpc647
Jun 10, 2013 11:48 AM
thomaswatk
Dec 3, 2011 02:56 PM
442scotty
May 13, 2009 05:42 PM
American Lead
Sep 18, 2007 05:18 PM
Want-A-Vert
Jan 15, 2007 12:02 PM
