Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
Serious ARP Bolts Questions from a relic.
Old Oct 14, 2025 | 05:49 PM
SY2455's Avatar
70 442 W-30
In regards to head bolts. I'm fully aware that ideally you would want to use a complete set and in that is where the questions is.
1. On the Oldsmobile engine there are a couple of headbolts that are also studs for AC Compressor as well as the Alternator Bracket, Are there also the same style ARP Bolts available ?
2. How are people getting around this minor obstacle as using those 2 bolts would be the weak link in a otherwise solid build?
Looking forward to seeing the solution to a relative minor issues for a car with AC.
Old Oct 14, 2025 | 07:27 PM
In the past, I reuse the double ended stock head bolts in those positions and torque them the same as the rest of the head hardware using the ARP lube on them.
Old Oct 15, 2025 | 03:52 AM
SY2455's Avatar
70 442 W-30
Thank you Oldscutlass. I was thinking that but wasn't sure and search turn up nothing until after I posted the question and then a really old post showed up.
Old Oct 15, 2025 | 04:05 AM
BillK's Avatar
Do you really need the ARP bolts ? I am building a 350 stroker right now with Edelbrock heads and I am going to use the stock bolts exactly for that reason. Unless you are building some outrageous engine I don't see the need for anything other than the stock bolts.
I checked just to be sure and the stock bolts are the same exact length as the ARP ones that Edelbrock says you "must use"
Old Oct 15, 2025 | 04:57 AM
SY2455's Avatar
70 442 W-30
Thanks Bill, I was mainly thinking about the added strength of them, however being our W-30 has A/C and PS that is where the questions came from. I should just probably stay with the original bolts.
Old Oct 15, 2025 | 07:48 AM
oddball's Avatar
The stock Olds head bolts are pretty good. If you want more clamping force then switch to studs and use extra long studs in those locations.
Old Oct 15, 2025 | 08:32 AM
Hammerdrop's Avatar
Use studs instead of bolts and you will have a male thread to which you can improvise a connection. I drilled my AC mount to a larger size and used a very short, I think, 5/8" allen head bolt cut off and internally threaded to make the connection.
Old Oct 15, 2025 | 01:12 PM
Pretty sure you can get ARP bolts with the stud for accessories.
Other options: use a stud in the location for the special bolt. Then drill the accessory bracket to fit the larger stud diameter.
Old Oct 15, 2025 | 03:27 PM
70W-32's Avatar
Pretty sure you can’t get ARP bolts with the stud for accessories.
r.
Matts right , call ARP and tell them you need a couple stand off bolts or studs
Rvsmith5
Jul 26, 2018 06:50 PM
Jan 1, 2018 12:42 PM
.Rocket.Man.
Jun 6, 2016 09:22 PM
James Wilson
Jul 30, 2012 09:42 PM
