olds transmission
olds transmission
=Are all gm transmissions the same bolt pattern? I have a 64 330 olds with the st 300 that is slipping in drive. So i think i want to replace it with a 350 turbo. I guess i will need some linkage for the kickdown then also? Thanks Phil
