Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
New and creative failure modes
Old Apr 13, 2021 | 09:34 AM
Just when you think you've seen it all...
Been trying to find a slow leak in one tire on the black 85 Delta. Got nowhere with soapy water. I finally pulled the wheel off the car, and purely by accident spilled some soap solution on the backside of the metal wheel.
Old Apr 13, 2021 | 09:53 AM
leftlaneonly's Avatar
WB weld fix it right up
Old Apr 13, 2021 | 11:45 AM
Actually, I pulled the tire off, cleaned that area on the inside, and there was nothing obvious. Coated it with Permatex Ultra Black (the motorhead's FlexSeal) and letting it dry right now. I wanted to use something flexible rather than JB Weld. I figure this is a good excuse to blast and paint the SSIII wheels for that car...
Old Apr 13, 2021 | 01:20 PM
F me! Metal fatigue?!?!
Edit: I have a slow leak in a trailer tire (that uses a purple SSIII....don't ask) that I should find like that.
Old Apr 13, 2021 | 01:24 PM
That is in the back of my mind. I was a little scared that I didn't see an obvious weld flaw. Unfortunately I don't have a magnaflux machine.
Old Apr 13, 2021 | 01:52 PM
tru-blue 442's Avatar
Old School Olds
Hell, that's nothing. The other day, I went to change the points in the vert and wondered why it wouldn't start after, only farted.
I ended up having to pull the dist. because the previous owner had it timed with the square peg in the round hole, lol. Took me a minute...
Old Apr 13, 2021 | 03:16 PM
Well, I painted the suspect area inside the rim with Permatex Ultra Black, put the tire back on, and no bubbles so far.
Old Apr 13, 2021 | 05:59 PM
mrolds69's Avatar
Those are both wacky failures. Maybe POR15 would have been a good thing to use in the wheel, Joe.
Old Apr 13, 2021 | 06:17 PM
I thought about that also, but I've found POR and the like to be a little brittle. That's why I used RTV. I'll be looking for a replacement wheel at Carlisle next week anyway.
Old Apr 14, 2021 | 04:41 PM
Yellowstatue's Avatar
This will be a case of 'Sloppy Joe'.
Trashylowrider
Wheels and Tires
Mar 20, 2019 06:46 AM
Jon442
Wheels and Tires
Nov 18, 2017 07:31 PM
Napoleon Solo
Apr 12, 2017 05:48 AM
mownhoj
Jun 30, 2016 07:18 AM
GothamCity
Mar 13, 2008 12:30 PM
