wheel well coating
Old February 20th, 2017, 02:57 PM
I'm indecisive. Or am I..
Napoleon Solo's Avatar
wheel well coating
Has anyone had experience or a recommendation for a wheel well coating that prevents the rock chips yet still looks good?
Thankyouverymuch...
Napoleon Solo is offline
Old February 20th, 2017, 03:51 PM
I've never seen anything that won't chip from a rock coming off the tire at high speed.
oldcutlass is online now
Old February 20th, 2017, 05:44 PM
cherokeepeople's Avatar
how about some of that rhinoliner stuff for truck beds??
cherokeepeople is online now
Old February 20th, 2017, 10:04 PM
That's what I was leaning toward. I'm going to look into it.
Old February 21st, 2017, 05:50 AM
x2
joe_padavano is offline
Old February 21st, 2017, 06:00 AM
Here is a way to do the coating yourself. I've read many reviews on this product and supposedly it works pretty well.
Amazon Amazon
Olds64 is online now
Old February 21st, 2017, 07:31 AM
I'd rather touch up the chips than use a rhino liner type coating if your building a show type car. Why not something like POR15.
Old February 21st, 2017, 12:04 PM
m371961's Avatar
For a non-show car I been thinking of Flex-seal. Used some on my floor and liked the way it came out.
m371961 is offline
Old February 22nd, 2017, 03:41 AM
chopolds's Avatar
I do bedliner on all my street driven, really nice builds. Smoother, shinier, and tougher than regular undercoat. I'd just add, use the stuff you have to mix with a hardener, and shoot with an undercoat gun. Not a single can product, it's no better than spray can undercoat.
chopolds is offline
Old February 22nd, 2017, 04:11 AM
Getting There
Ranzan's Avatar
did bedliner on the 67
Ranzan is offline
Old February 22nd, 2017, 05:34 AM
Wes, that's awesome!
Old February 22nd, 2017, 08:01 AM
gbledsoe3's Avatar
I sprayed the entire bottom with 2 coats of epoxy primer, seam sealed, another coat of epoxy, then 2 coats of Raptor Bedliner.
gbledsoe3 is offline
Old February 22nd, 2017, 08:04 AM
Gary, was the HVLP gun provided in the Raptor kit you used only one time use? Or, did you use a professional HVLP gun to apply it?
BTW, that looks sweet!
Old February 22nd, 2017, 08:14 AM
lemoldsnut's Avatar
I have had great results and I mean as good as guns costing a few hundred dollars from the $25 gun from harbor freight.
Was a total surprise but a good one.
lemoldsnut is offline
Old February 22nd, 2017, 08:16 AM
gbledsoe3's Avatar
It's called Shutz Gun sometimes but I cleaned it up with solvent and reused it over again. I plan to use again when I spray the trunk.
From Tooltopia
Old February 23rd, 2017, 07:03 PM
Thumbs up
This is all great stuff! I'm going to look deeper into all of the options. Thanks for the info gents.
Old February 24th, 2017, 05:37 AM
Keep us posted.
Old April 11th, 2017, 03:03 PM
Does anyone have any thoughts on brushing the stuff on? Will it look bad? It's my impatience getting the better of me. I'd prefer to spray it on to get even smooth coverage but my compressor is junk so I'd have to wait.
Old April 12th, 2017, 05:48 AM
Napoleon, I know POR 15 products can be applied with a brush. You need to make sure the bed liner stays "mixed" or "suspended." If you let bed liner sit in the can it will separate. That's why they suggest mixing it before shooting it (at least that's what the Raptor folks suggest).
w31man
Paint
January 9th, 2017 06:23 PM
CutlassS1972
Body work
August 21st, 2014 09:06 PM
The Bug Man
Body work
August 15th, 2013 12:53 PM
kevdog442
Body work
March 4th, 2009 07:29 PM
blonzz
October 25th, 2004 02:19 PM
Quick Reply: wheel well coating
