Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
Fluid recommendations?
Old February 19th, 2012, 08:29 PM
blleach's Avatar
I was just wondering what fluids would be recommended in my 1970 Cutlass Supreme? I have all GMs recommended fluids but, I wanted to see if anyone had better luck or better performance with a different weight, a full synthetic, or maybe even a different brand? I'm mainly wondering about the oil and transmission fluid but, feel free to share about the other fluids also.
blleach is offline
Old February 19th, 2012, 09:34 PM
1974 DELTA 88
AZ455's Avatar
I use Shell Rotella T in the engine, and Napa ATF in the transmission, which I once heard is Valvoline.
Most oils are going to be just fine, especially when changed at the recommended intervals. Many people swear by a particular brand for some reason or another. I like Rotella due to the ZDDP content.
AZ455 is offline
Old February 20th, 2012, 05:43 AM
Lady72nRob71's Avatar
Power steering would use the older Dexron 3 transmission fluid, like the tranny.
Brakes used DOT 3 brake fluid.
I do not have brand preference, but I stay away from the cheapies.
Although there are newer varieties of these, i do not want to intermix anything. The old ones worked well, so why try to change them...
No oil discussion for me - tired of it. You can do a search on oil types and zddp and find a mile of postings, most of which still hold true.
Lady72nRob71 is offline
oldscharm
November 11th, 2009 07:42 AM
cfair
Brakes/Hydraulic Systems
June 8th, 2009 12:37 AM
mwmjr
February 15th, 2007 06:58 PM
1BAD68"S"
December 2nd, 2006 04:48 PM
1BAD68"S"
August 24th, 2006 07:41 PM
Quick Reply: Fluid recommendations?
