Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
Early vs Late accessory setups
Old May 16, 2020 | 12:01 PM
android 211's Avatar
I'm working on a '66 425 to put in my '66 442 which I bought with an empty engine compartment. Originality isn't real important to me. It's an air conditioned car. I have two sets of '68-up accessories and brackets but no '65-'67 setups. Can I use the later setup on my 425 or is there a problem? Can the later setups be adapted?
Old May 16, 2020 | 12:19 PM
The blocks are dimensionally identical with any other BBO, so that is not an issue. The low-mount PS pump can be a clearance issue, but others have made it work in the 64-67 chassis. The early chassis is narrower than the 68-72 versions. And as always, the brackets, pulleys, and water pump all need to match or you'll have belt alignment issues.
Old May 16, 2020 | 12:47 PM
I thought there was some problem with the balancer not fitting both earlier and later engines and the bottom pulley having a different attachment pattern to the balancer
Old May 16, 2020 | 01:32 PM
Nope. Both the pulley bolt pattern and the offset of the pulley mounting surface on the balancer are the same for all 1964-1990 motors.
Old May 16, 2020 | 01:45 PM
therobski's Avatar
I used the 68 and up brackets, PS pump etc. Like Joe mentioned it's a little tight in a 64 but all worked out. Installed Old Air Products A/C. Also used a I believe a 68 on up Corvette power brake booster, it provides the clearance if you need to remove the valve cover for service.
Old May 16, 2020 | 03:42 PM
REO442's Avatar
Thumbs up those plug wire mounts
Nice set up , what is the source for the plug wire holders?
Old May 17, 2020 | 07:24 AM
therobski's Avatar
Thanks, Summitt Racing ....
Old May 17, 2020 | 12:08 PM
Thanks for the information.
Old May 17, 2020 | 03:53 PM
therobski's Avatar
Yes sir!
DR_DAN
Aug 3, 2015 04:00 PM
1969w3155
Jul 5, 2013 12:21 PM
507OLDS
Jun 27, 2011 05:38 AM
butchashop
Jun 8, 2010 10:11 AM
425cid_260Z
Jul 25, 2007 05:05 AM
