Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
Drag link , arm bushings , HELP
Old May 4, 2017 | 11:21 AM
Jetstar Holland's Avatar
Hello other side of the world.
Today ik have been to the m.o.t test in holland with my oldsmobile Jetstar 1 6.5l 394 engine 1964.
And now i have to fix some things.
Control arm bushings, idler arm and center link.
Does some one know the part numbers for the control arm bushings front of the car lower en upper ones.
That i can order the ones i need.
And i need a drag link/center link part number and where could i buy one ???.
Greetings from Holland.
Old May 4, 2017 | 07:03 PM
Yellowstatue's Avatar
Hello from far away; Front lower control arm bushing PN 388214/pair. Front upper bushing PN388213/pair. Idler arm PN 5676459 W/PS Saginaw...PN 588112 W/Thompson Products. Relay Rod/Center Link PN Thompson Products 384767 W/PS, or after jobs Saginaw 5679828 W/PS.
Old May 5, 2017 | 07:18 AM
Assuming those are the GM part numbers, good luck trying to find them. Some items might still be available from Moog, but I suspect that parts like the center link and idler arm are no longer made. Check with Craig from Mobileparts for N.O.S. replacements. Rare Parts is another source.
Old May 5, 2017 | 11:06 AM
Charlie Jones's Avatar
Phantom Phixer
Upper control arm bushings;
http://www.ebay.com/itm/New-Front-Up...BYhiD5&vxp=mtr
Lower control arm bushings ;
http://www.ebay.com/itm/Suspension-C...1YmcUi&vxp=mtr
Idler arm;
http://www.ebay.com/sch/i.html?_from...r+arm&_sacat=0
Center link;
http://www.ebay.com/sch/i.html?_odkw...+link&_sacat=0
Be aware , that Oldsmobile bought two types of steering parts for their "big cars" in this era.
They got parts from their own GM Saginaw division and they also bought parts from the Thompson (TRW) company . The two kinds cannot be mixed . The tapers where the parts connect are different.
The easiest way to tell what kind of steering system you have , is to look at the bottom of the pitman arm for a forging number . The pitman arm is attached to the steering box .
If the number begins with 56 and has seven digits , then it is a Saginaw system .
Anything else will be Thompson (TRW) or "alternate" system .
Also , power and manual steering systems had different components .
Old May 5, 2017 | 12:41 PM
m371961's Avatar
Charlie, does this apply to other model years? Beats measuring.
Old May 5, 2017 | 12:46 PM
Thanks for the help.
Now i know what i need.
And the difference between the drag links.
First i didn't understand the 2 part numbers for it but now i do.
Good to know.
Greetings Barry
Old May 5, 2017 | 09:48 PM
Phantom Phixer
Wink
Yes , as far as I know .
Saginaw part numbers were seven digits and started with 56 .
Example , 5676457 .
Old May 8, 2017 | 11:26 AM
Some other questions
Hello again from Holland.
I alsof need to put on new front upper en lower bumpers.
My oldmobile service manual nr 3 .
Shows me that front suspension 33-34-35-36-38-39 series are the same.
And fusick automotive sells them for starfire (36 series).
Will they fit on my jetstar 1 ??????.
And does any one know where i could get rear shock mount grommets.
Greetings Barry.
Old May 8, 2017 | 12:43 PM
Will the fit on my jetstar 1 ??????.
Greetings Barry.
Old May 8, 2017 | 01:17 PM
Yes. The suspension is the same on all 1963-64 Olds full size cars. The parts are the same.
Old May 11, 2017 | 11:16 AM
It's a siginaw centerlink crappppppp
Now i found out what kind it is but now the next thing where to buy one online.
Ik found out in my manual that the center link goes in the pitman arm from below.
Pitman arm (3300 only)
File Type: png
Old May 17, 2017 | 11:28 AM
Found one.
I found a centerlink and idler arm in Holland.
Some times things are closer then you think.
Greetings Barry.
Old May 17, 2017 | 11:31 AM
Parts
File Type: png
Old May 17, 2017 | 12:45 PM
Do they sell lottery tickets in Holland...? Nice score, you are one lucky guy.
Old May 25, 2017 | 12:43 AM
Swaybar bushings.
Yes they sell them in holland but i never win it.
I bought a set stabilizer bar bushings for a starfire 1964.
They are to smal where can ik find the set in need.
Greetings Barry.
Old May 25, 2017 | 04:29 AM
Moog K440 or K5255 come as a kit.
BILL DEMMER
34
Jun 8, 2021 11:45 PM
RandyS
Nov 30, 2019 02:46 AM
shovel55
Jul 7, 2012 04:20 PM
Jayycobb
Jun 9, 2012 09:15 PM
scubastever
Oct 6, 2009 09:28 AM
