Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
Conversion to HEI
Old Dec 2, 2009 | 08:01 AM
buds68a77's Avatar
Conversion to HEI
Joe,
Have put on new HEI dist and appropriate plugs/gapped, wires: set static timing to 8 deg. and have adj vacuum advance.
Can't seem to get enough adv. (around 22 deg.) Knocks under acceleration when it looses vacuum.
What are correct settings for a '65 425 10:1 comp eng. switching to HEI?
Static, centrifugal, and vacuum, etc?
With the old style dist I was at 8 deg w 34 total degrees with no adj. adv. and pertronics setup.
Thanks , Bud
Have read threads associated w/HEI and there is conflicting info.
joepenoso
Jun 4, 2014 01:56 PM
oldscruiser
Feb 15, 2011 12:44 AM
Frankenpez
Feb 8, 2009 07:38 PM
JoshF85
Mar 15, 2005 10:50 AM
