Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
'65 442 Air Cleaner Issues
Old May 11, 2016 | 03:32 PM
777stickman's Avatar
About a year ago I replaced the stock 4GC (not original dammit and it was giving me fits) with a Street Demon. Very nice carb, minor install mods and easy to tune.
The issue is with the '65 air cleaner base. The 4GC has a smaller throat size than the later Q-Jets, Holleys, Demon"s, etc. The aftermarket base I used is 1 1/2" smaller in OD than the lid. Consequently there is more engine heat going down the carb than I would like. Been running it this way for over a year with no real issues, but would like to somehow seal it up for a cooler intake air temp and better suck for the blow-by gasses.
Is there a base out there that has the Q-Jet throat size that will fit the original '65 442 lid which has a (EDIT) 17 5/8" OD and correct size filter?
Thanks.............Steve
Old May 11, 2016 | 03:47 PM
Why not modify your original base to fit the new carb? Or fabricate a ring to go around the new base to fill the opening.
Old May 11, 2016 | 05:34 PM
The 1966 and 67 cars used Qjets with a similar air cleaner. One of those bases should work.
Old May 12, 2016 | 04:23 PM
Thanks Joe: I checked and all 3 years use the same filter element. Would you happen to have a base laying around??
Old May 12, 2016 | 04:52 PM
lemoldsnut's Avatar
Pretty sure I have it.
just sent PM
Old May 14, 2016 | 03:05 PM
Not going to modify the original base just because it's original. If I did try that I'd probably need some of the suitable explosives you mention!! The ring thing maybe my only other option if I can't find a suitable base...............Thanks
Old May 14, 2016 | 03:16 PM
Can someone measure the bottom OD of their 66--67 442 chrome single snorkel air cleaner lid for me?
My 65 lid OD is 17 1/2" and the base OD is 17 5/8". Just need to know for sure if a 66--67 442 base will work for my project in the original thread.
Thanks............Steve
Old May 14, 2016 | 03:29 PM
lemoldsnut's Avatar
It's correct as I pictured to you.
Larry
Old Jun 1, 2016 | 04:17 PM
Another thank you Joe. Your "should work" needs to be "will work". Picked up a '67 442 lid & base. Obviously I can't use the '67 lid on my '65, but the base was a perfect fit for my project.
Again.........THANK YOU!!!
Old Jun 2, 2016 | 04:40 PM
therobski's Avatar
Should turn out like this...( without the snorkel) Good job guys! Question 65's with a 4-speed did not have a snorkel air cleaner correct?
Old Jun 2, 2016 | 06:40 PM
I'll probably get reamed for this, but. I'm pretty sure all 65's had the snorkel. I think the open air cleaner came to be with the 67 4 speed, although my Fremont built 67 442 4 speed came with a snorkel??
Bernhard
Aug 6, 2021 04:21 AM
BeenThere
Sep 20, 2015 07:47 AM
69CutlassAlex
Dec 2, 2011 08:01 AM
dan1s
Apr 17, 2010 08:14 AM
Viper
Aug 13, 2008 10:58 AM
