what steering gear to use for 67 442
Old Oct 3, 2014 | 12:31 PM
garyr6169's Avatar
want to add power steering to my 67 442. have pump and mounting from 69 cutlass ready to go. what steering gear do I want to use so I can reuse my pitman arm and rag joint?
Gary
Old Oct 3, 2014 | 12:41 PM
steverw's Avatar
I bought a Lares for mine. I got the 10.1 ratio, should be quick, I think they also have a 12.1, or stock ratio as well. It came with a new rag joint. They use IROC internals for the 10.1 ratio. They have the 3 bolt or 4 bolt housings. The one i bought had the same casting number as my old one, its a 4 bolt. I bought mine from Rock Auto, but you can also Google Lares Steering and buy direct from them. I havnt tried it yet, but it is a GM rebuilt box, It looks nice, all shiny and new...ish. Your pitman will bolt right on. I think there is a 75 dollar core charge you will get back if you want to send your old one in, after you get the rebuilt one. Your old rag joint should bolt right up too.
Steve
Old Oct 3, 2014 | 01:47 PM
442nut's Avatar
So if you have manual steering now you will not be able to re-use the pitman arm. The hole on the box side of the arm is smaller than a Power Steering pitman arm. I did the Jeep Grand Cherokee swap in my '66 442. Details of this swap can be found on this posting: https://classicoldsmobile.com/forums...ap-w-pics.html
Old Oct 3, 2014 | 03:26 PM
RandyS's Avatar
Gary
Rock Auto has several for you to choose from, and they come with the rag joint. As mentioned, you will need a matching pitman arm, as the MS one won't work.
Old Oct 3, 2014 | 03:42 PM
garyr6169's Avatar
Is the inside diameter of the power steering gear pitman arm larger than the manual? I have a gear off of a 76 trans am and my manual gear pitman arm is not large enough... also the shaft for the rag joint is larger... do I go back to the drawing board or do you think the pitman arm for power steering will work? The gear was given to me, so the price was right! but only if I can make it work.
yankees
Nov 3, 2014 05:00 PM
JpMotorsports
May 15, 2014 07:08 AM
drjr56
Sep 9, 2012 08:05 PM
wmlewis
May 17, 2012 11:37 AM
mainedogg72
May 24, 2006 10:13 PM
