Tie rod adjusting sleeve??
Old Jun 30, 2012 | 04:17 PM
70Cutlass_408's Avatar
Which is the outer and inner tie rod, one tie rod was tightened into the adjusting sleeve using opposite thread and the other was normal thread. So which is the outer and which is the inner tie rod.
Thanks.
Old Jun 30, 2012 | 05:19 PM
Highwayman's Avatar
I've got tie rods and drag link from a 70 Chevelle in my stuff. It should be the same as Cutlass. The outer tie rods are right hand thread with the zerk on top. The inner are left hand threads with the zerk on the side. Inner and outer appear to be the same length.
Old Jun 30, 2012 | 09:52 PM
Inner and outer tie rods are supposed to be opposite threads. The inner is the one that hooks up to the center link. The outer attaches to the steering knuckles.
Old Jun 30, 2012 | 09:59 PM
oldzy
Jun 12, 2011 08:24 PM
amphicar770
Jan 18, 2010 02:02 PM
amphicar770
Jan 16, 2010 06:44 PM
leslie
Feb 9, 2008 05:31 AM
leslie
Jan 26, 2008 04:06 PM
