Stock Moog replacement springs
Old Jul 24, 2015 | 06:28 PM
  #41
61reoldsman's Avatar
If you want a little more lift , the Moog 5413 are what I just took off that are a 167 lb rate . Those springs would be 3/4''-1" higher than the 5401 I have on now .See the picture with these springs from before.
Old Jul 25, 2015 | 04:37 PM
  #42
Macadoo's Avatar
Well I'll be darned
Looky what I found still attached to one of the rear springs.
[IMG][/IMG]
The # 9777794 seems to cross reference as the Moog 5401 you have reoldsman.
Soo....the 6321 seems to be the closest match with a one inch taller spring but with slightly lower values on the load (5401 = 727; 6321 = 689) and the spring rate (5401 = 129; 6321 = 119). Seems like the 6321 might squash a little more than reoldsman's 5413 but those have a slightly smaller I.D. from 5.580 to 5.530. Did that cause you any install problems reoldsman? And do you still have the springs and are willing to sell?
Fummins
Suspension & Handling
Oct 9, 2012 11:22 AM
doc
Mar 30, 2012 08:41 PM
RetroRanger
Oct 3, 2011 07:07 AM
JeremyTA
May 16, 2011 06:29 PM
defiant1
Apr 16, 2011 10:34 AM
