Steering wheel vibrations - to one side only
Old October 12th, 2013 | 04:50 AM
Seff's Avatar
My steering wheel vibrates when I steer right only. Not big vibrations like when wheels are unbalanced, but a small tension-like vibration. Worm gear too tight/loose? Wheel bearing(s)? No odd sounds.
Thanks.
EDIT: Bonus question: The 12.7:1 steering boxes out of '71 Camaros have less of a turning radius than my stock steering box but are fixed ratio, right? There's a cheap one floating around, and I've read I can 'just' put the stock end/cover plate on the Camaro box and obtain the same turning radius I have with the stock box. Have I understood this correctly?
Old October 12th, 2013 | 05:59 AM
brddg's Avatar
I would guess wheel bearing. Check the outer left first. Does it happen on acceleration or deceleration or both?
Old October 12th, 2013 | 07:33 AM
You might also consider your front suspension bushings - one that is too loose or soft can do this.
As for the steering, I don't remember exactly, but Jim Shea lays it out very clearly in one of his papers on the subject.
This article has some nice illustrations of what it all looks like inside.
Old October 12th, 2013 | 07:53 AM
Seff's Avatar
It happens at acceleration, deceleration, and constant speeds. Interestingly enough, it also happens in reverse. I'll pop off the wheel and check the bearing.
Eric: You're thinking control arm bushings? They're all new and poly, came with my tubular control arms.
Might it be a blown ball joint in a steering arm?
Regarding steering, if I'm reading it correctly, the '71 Camaro came with a variable ratio steering box. Oh well.
Old October 12th, 2013 | 07:56 AM
I don't think so. I think that would misbehave all the time.
Old October 12th, 2013 | 07:58 AM
Seff's Avatar
So we're down to the bearing. Hmm.
Old October 12th, 2013 | 07:59 AM
I guess. These things can be hard to diagnose.
Old October 12th, 2013 | 08:02 AM
Seff's Avatar
It's just about free to check. I'll update you guys on the results.
Old October 12th, 2013 | 08:04 AM
pogo69's Avatar
morgan
might want to rotate l-r front tires just to rule out the wheel also
Old October 12th, 2013 | 08:05 AM
Seff's Avatar
I'll try that first, then. Thanks.
Old October 12th, 2013 | 09:12 AM
brown7373's Avatar
Might also be a belt beginning to separate from the tire
Old October 12th, 2013 | 10:34 AM
Seff's Avatar
I started her up again. It happens when she's at a standstill as well. This is power steering we're dealing with. But, I'd think that rules out bearings and tires as the culprits, yes?
Old October 12th, 2013 | 12:25 PM
Yes, I'd say. If it happens at a stop, it's your power steering. Maybe some air in there. I'm not sure beyond that.
Old October 12th, 2013 | 12:28 PM
Seff's Avatar
Well, I'll fool around. The CSM had no symptoms like it.
Octania
January 30th, 2016 10:18 PM
Octania
July 16th, 2015 10:53 AM
Finn5033
July 9th, 2013 01:10 PM
ramairthree
July 4th, 2013 03:32 PM
MDchanic
Drivetrain/Differentials
27
July 8th, 2011 04:20 AM
Quick Reply: Steering wheel vibrations - to one side only
