Steering wheel vibrations - to one side only
Old Oct 12, 2013 | 03:50 AM
Seff's Avatar
My steering wheel vibrates when I steer right only. Not big vibrations like when wheels are unbalanced, but a small tension-like vibration. Worm gear too tight/loose? Wheel bearing(s)? No odd sounds.
Thanks.
EDIT: Bonus question: The 12.7:1 steering boxes out of '71 Camaros have less of a turning radius than my stock steering box but are fixed ratio, right? There's a cheap one floating around, and I've read I can 'just' put the stock end/cover plate on the Camaro box and obtain the same turning radius I have with the stock box. Have I understood this correctly?
Old Oct 12, 2013 | 04:59 AM
brddg's Avatar
I would guess wheel bearing. Check the outer left first. Does it happen on acceleration or deceleration or both?
Old Oct 12, 2013 | 06:33 AM
You might also consider your front suspension bushings - one that is too loose or soft can do this.
As for the steering, I don't remember exactly, but Jim Shea lays it out very clearly in one of his papers on the subject.
This article has some nice illustrations of what it all looks like inside.
Old Oct 12, 2013 | 06:53 AM
Seff's Avatar
It happens at acceleration, deceleration, and constant speeds. Interestingly enough, it also happens in reverse. I'll pop off the wheel and check the bearing.
Eric: You're thinking control arm bushings? They're all new and poly, came with my tubular control arms.
Might it be a blown ball joint in a steering arm?
Regarding steering, if I'm reading it correctly, the '71 Camaro came with a variable ratio steering box. Oh well.
Old Oct 12, 2013 | 06:56 AM
I don't think so. I think that would misbehave all the time.
Old Oct 12, 2013 | 06:58 AM
Seff's Avatar
So we're down to the bearing. Hmm.
Old Oct 12, 2013 | 06:59 AM
I guess. These things can be hard to diagnose.
Old Oct 12, 2013 | 07:02 AM
Seff's Avatar
It's just about free to check. I'll update you guys on the results.
Old Oct 12, 2013 | 07:04 AM
pogo69's Avatar
morgan
might want to rotate l-r front tires just to rule out the wheel also
Old Oct 12, 2013 | 07:05 AM
Seff's Avatar
I'll try that first, then. Thanks.
Old Oct 12, 2013 | 08:12 AM
brown7373's Avatar
Might also be a belt beginning to separate from the tire
Old Oct 12, 2013 | 09:34 AM
Seff's Avatar
I started her up again. It happens when she's at a standstill as well. This is power steering we're dealing with. But, I'd think that rules out bearings and tires as the culprits, yes?
Old Oct 12, 2013 | 11:25 AM
Yes, I'd say. If it happens at a stop, it's your power steering. Maybe some air in there. I'm not sure beyond that.
Old Oct 12, 2013 | 11:28 AM
Seff's Avatar
Well, I'll fool around. The CSM had no symptoms like it.
Octania
Jan 30, 2016 09:18 PM
Octania
Jul 16, 2015 09:53 AM
Finn5033
Jul 9, 2013 12:10 PM
ramairthree
Jul 4, 2013 02:32 PM
MDchanic
Drivetrain/Differentials
27
Jul 8, 2011 03:20 AM
