Steering turns when starting the car
Old May 11, 2015 | 11:24 PM
Haidda's Avatar
Hello, i´m a little bit confused about my steering gear box. I made my steering gear box because it was leaking (new teflon rings, new bearings, all new). When I start the car - and the steering pump starts working - the steering turns full to the left on its own!! What did i wrong? How can I fix that?
Thank you very much
Daniel
Old May 12, 2015 | 04:07 AM
Sounds like your spool valve is sitting a bit off center, causing it to provide boost in one direction when the steering wheel is pointed straight ahead.
Unfortunately, I can not see an alternative to taking it apart and having another look at it.
There may be someone here who has experience with this and can give you more specific advice.
Welcome to ClassicOlds.
Old May 12, 2015 | 06:27 AM
Haidda's Avatar
Thank you! Where is the center of the spool valve? How can i adjust this?
Old May 13, 2015 | 04:21 AM
You need to re-read the part of the "Steering" chapter in the Chassis Service Manual called "Power Steering Gear Operation."
It describes and illustrates the action of the spool valve, and gives some troubleshooting information.
If I have to guess, I would guess that one of the spool valve sealing rings is damaged or cocked, allowing fluid to leak past it.
Old May 13, 2015 | 09:41 AM
RROLDSX's Avatar
Could be dangerous?
Had that happen on a mopar and it would suddenly without cause or notice spin violently to the side. I'm positive if I would have tried to stop the spin it would have broke my wrist. Luckily I was driving slow and was able to stop quickly. Hopefully that won't happen to an Olds but I would be caution and fix it correctly. Sorry I can't be more help.
Old May 17, 2015 | 10:51 PM
Haidda's Avatar
Checked the gear box yesterday. All the sealings are in a very good condition but how many ***** are in the gear box? There are only 22 ***** in it! There are enough to "fill the wormshaft" but no ball is left to fill the "ball guides"!
bccsrc
Nov 29, 2011 11:08 PM
Lady72nRob71
May 22, 2010 06:46 AM
stingger68
Mar 16, 2010 01:30 PM
jmlondon
Drivetrain/Differentials
Dec 8, 2008 08:13 PM
jaco
Jan 28, 2007 12:54 PM
