steering & handling issues
My 83 cutlass pulls all of a sudden while im driving @ high speeds, Im pretty sure it's the flex coupling. I got very llittle experience in this & im not sure how to pull it off. Can anybody help? I kinda see what's holding it together but no way to unscrew it.
Are you talking about the flex coupling from the steering column to the box? If so that will not make the steering pull. I would look at all your front end parts as the culprit. Sometimes a tire rotation will also correct this issue.
im pretty sure it's not my front end, I've replaced almost every part including my steering gear box , when I say it pulls, well it actually jerks to the right& it's hard to cotrol , I've read also in a few places that these symptoms are do to the flex coupler
Does the coupler flop around? All it is 2 bolts and a flexible piece of rubber. Is jerking when going over a bump, a rut, or tar lip? I'd double check my upper and lower control arm bushings, etc.
cuttysupreme72
September 22nd, 2012 04:31 AM
67 Olds 442
Suspension & Handling
April 3rd, 2012 06:38 AM
