Steering gear replacement - steering wheel misaligned
Old Apr 30, 2022 | 02:16 PM
tgilligan's Avatar
Hi,
Replaced my worn out steering gear with a new Lares on my ‘70 Supreme. Also replaced the coupler. After taking a road test, noticed the steering wheel is off just a bit. Could this be rectified by removing pitman arm and readjusting? Box was centered (lock-to-lock) and coupler was installed with flat spot aligned. It lined up perfectly with my steering shaft when I put it back in. Wondering if I’m off a tooth or two on the pitman. Any ideas?
Old Apr 30, 2022 | 03:27 PM
Originally Posted by tgilligan
Hi,
The pitman shaft has four wide splines at 90 deg intervals. You can't install it one tooth off. You need to adjust the tie rods to center the wheel.
Old Apr 30, 2022 | 03:32 PM
tgilligan's Avatar
Thanks Joe. Is this common to need to do if no other suspension components were touched and just the pitman arm was disconnected?
Old Apr 30, 2022 | 04:07 PM
Yes. Manufacturing tolerances add up.
Phoenix8990
Suspension & Handling
15
Nov 2, 2021 07:56 AM
tgilligan
Apr 24, 2021 05:58 PM
Jimoldsfan
Sep 25, 2013 01:38 PM
67townsedan
Sep 16, 2013 03:25 PM
Jetstar 88
Jan 31, 2012 03:29 PM
