Steering Gear replacement
Old Dec 22, 2022 | 07:23 AM
stevdak's Avatar
I am looking to replace my steering Box on my 66 442, Mine is sloppy, worn and I'd like a better gear ratio. I read a few threads where the 92-98 Jeep Grand Cherokee gear box is the ideal replacement. In my area, the junkyard prices are high, so a rebuild would be my choice. I'm finding the 92-95 JGC gearbox is different from 96-98, Rockauto shows cardone 27--7525 vs 27-7560 respectively. Does anyone know which unit is the best choice? I'd like to keep my turning radius the same if at all possible.
Also, I have a buddy with a gearbox from a 92 Firebird, 3.5 turns lock-to-lock (Cardone 27-6530). This unit was also used in 1980s GMs such as Olds Cutlass, El Camino, Impala and Monte Carlo. Does anyone have experience using this or similar gearboxes? Wondering if I'd lose turning radius.
Any help would be appreciated.
Old Dec 22, 2022 | 09:26 AM
66luvr's Avatar
This guy has sold a lot of steering boxes on V8Buick.com, as well as other ways. He has good feedback from the buyers on the Buick forum.
I have not bought from him, I sent mine out to be rebuilt with quick ratio upgrade.
Carhex quick ratio Christmas sale.
Limited supply of 30 boxes
$340.00 shipped That's 30 bucks off regular price.
Carhex quick ratio steering boxes
Factory quick ratio power steering boxes.
Direct bolt in and in some cases upgrade
no hose adapters needed uses factory rag joint and looks factory.
Direct bolt in replacement upgrade
Quick ratio with full turning radius 3 1/4 turns lock to lock with 87 deg of turning radius
with my box you will not lose turning radius.
Direct bolt in for all 64 to 76 GM cars
$340 shipped for just the box $390.00 shipped with new rag joint. .
Price includes hosing and conversion charge that is refundable if you return a good core.
Thanks to my CORE supplier
I AM ABLE TO LOWER THE PRICE 30 BUCKS FOR CHRISTMAS
If you return a core you will get $70.00 back for the housing and an additional 90 if the core you send back is a factory quick ratio. Up to $160.
CORES CAN NOT BE RUSTED NOT PITTED NO BROKEN BOLTS NO STRIPPED THREADS NO PITTING
core charge will be refunded after my rebuilder inspects them.
1 year warranty. Anything goes wrong within the year I cover shipping back in forth in a flat rate USPS box.
After the year I still warranty the box you just cover shipping.
If you want to try out box and don't like it. Cover shipping cost and ship it back for a full refund. You will only be out the cost to ship it back.
Deal dose not apply if you already sent back the core.
I'm now able to offer new rag joints with your order for an extra $50.00 bucks.
To order all I need is your PayPal email address.
I will send you an invoice.
Let me know if you want a rag joint or not when placing your order.
I will send you a PayPal invoice as soon as it's paid a label will be printed and a box will be on its way to you.
If you have any questions feel free to call me
Hector
626 488 5472
I also have 605 boxes 808 boxes 9/2 boxes and jeep boxes in stock
We also have pitman arms for all GM cars in stock
Limited supply of power steering pumps in stock.
THANK YOU FOR SUPPORTING OUR SMALL BUSINESS.
You can also buy a rebuilt from Advance Auto Parts
Cardone Steering Gear 27-6509 - Advance Auto Parts
They state it is a fast ratio box. Total Turns Lock to Lock:
2.6 to 2.3. Copied from their website and pasted here.
Old Dec 22, 2022 | 10:12 AM
Be aware that total turns/ratio is not the only thing that matters. The torsion bar that is part of the input shaft controls the rotary valve that regulates how much hydraulic pressure is applied to the piston in the steering box.
The thicker the bar, the more effort required to twist it and activate the rotary valve, so the greater the steering effort. "One finger" power steering boxes have the smallest torsion bar. High effort boxes have a larger one. You can have a quick ratio box that is still "one finger".
Old Dec 30, 2022 | 06:04 PM
stevdak's Avatar
Follow up: I checked the turning radius of my buddy's steering gear box removed from a 92 Firebird (part # 7826692). The radius seemed to be the same as my original so I got the gear box and matching pump. The upgrade was similar to others who upgraded using the JGC steering gear, I needed a new rag joint, new hoses with metric o-ring fittings. The pump would not fit my brackets so I swapped the pressure relief valve and output fitting to upgrade my existing pump. I got it all installed and took it for test drive. The difference in the drive is amazing, with more resistance and responsiveness. I confirmed the turning radius was not effected. For anyone considering the upgrade, there is no need to limit your options to Jeep Grand Cherokee parts, the unit I used is common across many GM models in the 80's and 90's.
Old Dec 31, 2022 | 07:30 AM
Due to the way they are mounted in the car, the F-body box has internal stops that will result in asymmetric turning radii to the right vs to the left. Changing these stops requires complete teardown of the box. The Monte SS box is a better choice, or an aftermarket rebuilt.
Old Dec 31, 2022 | 08:14 AM
ART T's Avatar
1998/2000, Jeep Grand Cherokee.
Old Feb 24, 2023 | 02:45 PM
Anyone have the Dorman part number for the rag joint needed for this swap?
Old Feb 24, 2023 | 07:19 PM
nicks1966's Avatar
dorman 31011
lares 200
Old Feb 25, 2023 | 07:40 PM
Originally Posted by nicks1966
dorman 31011
lares 200
Thanks!
Skydog9
Suspension & Handling
Oct 5, 2021 09:50 AM
Phoenix8990
Jul 26, 2021 09:28 AM
tgilligan
Apr 24, 2021 05:58 PM
brown7373
Apr 29, 2015 06:13 PM
Al Graaf
Sep 16, 2012 03:29 PM
