Rear Sway Bar Added
Old Dec 24, 2021 | 11:08 AM
Tuffnut's Avatar
Rear Sway Bar Added
I’m putting a new rear sway bar on my 75 Supreme. Will there be a noticeable difference in handling? Going to be 4-5 months before I can test it out here in Ontario.
Old Dec 24, 2021 | 11:16 AM
66SportCoupe's Avatar
Definitely yes!
Old Dec 24, 2021 | 11:38 AM
Without question.
Old Dec 24, 2021 | 11:56 AM
Yellowstatue's Avatar
You won't notice any difference in the snow.
Old Dec 24, 2021 | 12:09 PM
Tuffnut's Avatar
Thanks guys. I’m glad it is worth it for the improved handling, money spent and sore shoulder blades and neck muscles. 👍
Old Dec 24, 2021 | 12:30 PM
Sugar Bear's Avatar
There is no chance I'd do that to mine and yes it will handle differently in a bad way. Remove it and replace it with an ANTI-sway bar...
Seriously, you will love the difference.
Good luck!!!
Old Dec 24, 2021 | 02:17 PM
I like mine.
Old Dec 24, 2021 | 03:14 PM
Make sure your rear LCAs are up to the task. Are they all boxed on the colonnade cars?
Old Dec 24, 2021 | 03:36 PM
Nope. The rear sway bar on the 1973-77 cars bolts to the bottom of the LCA, and the factory just used a sheet metal insert that bolts into the open side of the arm. It's only a few inches long and does not create a fully boxed LCA like on the earlier cars.
See item #35.
Old Dec 25, 2021 | 02:22 AM
Ozzie's Avatar
My 442 always had one, so I haven't experienced going from without to with, but my guess is that you will see a difference.
Old Dec 28, 2021 | 06:22 AM
BlueCalais79's Avatar
You will notice an improvement when you go around your first bend. I share your pain in that the moment won't be for another few months. Also, IMHO I found its better to do this job when the car is up on a lift. I tried putting mine on ground level and it did not work out well. Once it was on a lift getting something else done it was re-installed and I noted improved handling just from that.
edzolz
Apr 16, 2021 04:49 PM
donfitzgerald
Suspension & Handling
Feb 18, 2021 03:33 PM
donfitzgerald
May 2, 2015 05:46 AM
willj
Jul 19, 2011 06:49 PM
oldzy
Dec 4, 2010 01:06 PM
