Rear Sway Bar Added
Rear Sway Bar Added
I’m putting a new rear sway bar on my 75 Supreme. Will there be a noticeable difference in handling? Going to be 4-5 months before I can test it out here in Ontario.
See item #35.
You will notice an improvement when you go around your first bend. I share your pain in that the moment won't be for another few months. Also, IMHO I found its better to do this job when the car is up on a lift. I tried putting mine on ground level and it did not work out well. Once it was on a lift getting something else done it was re-installed and I noted improved handling just from that.
