Rear shock lower mount removal on '72 98
Old Jun 1, 2023 | 05:25 PM
jpilk99's Avatar
I'm trying to remove the bolt that holds the lower end of the shock in place. The back is spinning and it's rounded. I see a slight flat side but that seems oddly ...hokey to try and get, what, big ol' channel locks on it while running an impact hammer on the nut end? How do smart people free up their A-Arms to swing down? I tried latching vise grips on the inner collar in between the rounded end and the nut, but no luck.
Old Jun 1, 2023 | 07:52 PM
Just cut it off, the new shocks should come with new mounts.
Old Jun 2, 2023 | 04:46 AM
Interesting. I recently did the front shocks on my 71 98. At the time I noticed my rear shocks were just like yours. Rusty, worn & needing replacement.
I should check the bottom mounts of my rear shocks. I bet they have similar hardware.
x2 on using a hacksaw to remove the hardware
Old Jun 2, 2023 | 05:39 AM
jpilk99's Avatar
I wasn’t planning on replacing them. So cutting isn’t my top idea. I’m adding lifts under the coils….
Old Jun 2, 2023 | 05:41 AM
Then put a wrench on the flat area on the opposite side.
Old Jun 2, 2023 | 05:57 AM
You can use a grinder on the nut seen in your last picture. Then just replace the bolt and nut with Grade 8 hardware from your local hardware store.
Old Jun 2, 2023 | 06:26 AM
Replacement lower shock mounts are readily available.
Amazon Amazon
Old Jun 2, 2023 | 08:07 AM
Thanks for the link Joe.
tkcutlass
Aug 3, 2020 10:32 AM
forstatd
May 9, 2020 01:15 PM
jpatfarrell
May 30, 2019 05:26 AM
L77F85
Jun 29, 2017 05:33 PM
garys 68&72
Drivetrain/Differentials
15
Apr 5, 2015 03:13 PM
