Need help removing 71 442 steering wheel …
Old Mar 25, 2022 | 04:31 PM
pnagy23's Avatar
I bought a pulley puller but still can’t get steering wheel off. Am I missing something ?
Old Mar 25, 2022 | 04:32 PM
66SportCoupe's Avatar
We will need more information to help you. Did you take the nut off?
Old Mar 25, 2022 | 04:34 PM
pnagy23's Avatar
Lol of course
Old Mar 25, 2022 | 04:45 PM
Did you eat your Wheaties? How about spinach?
Look, seriously, you haven't given us a lot to go on. WHICH steering wheel, the standard two spoke or the sport wheel hub? And what exactly is the problem? I usually use a breaker bar or long 1/2 drive ratchet to turn the screw on the puller.
Old Mar 25, 2022 | 07:44 PM
v8al's Avatar
Registered Olds Owner
It may just be semantics but you said "pulley puller" You need a "steering wheel puller" that looks like the following:
Thread outside bolts into the steering wheel and then tighten the center screw on the puller.
Old Mar 26, 2022 | 01:49 AM
pnagy23's Avatar
I have the sun 3900.
Old Mar 26, 2022 | 09:30 AM
The Sunex 3900 should work fine. Depending on the wheel, you may need to separate the wheel from the hub, and then pull the hub. It's just a splined shaft.
JLane92
Mar 24, 2018 10:20 PM
Cutty72
Oct 18, 2011 08:19 PM
RAMBOW
Mar 7, 2011 03:18 PM
Southern_Hospitality
Jun 6, 2010 02:00 PM
