Moog rear control arm bushing part #?
Old October 18th, 2018, 01:40 PM
Joe Ralph
72442455's Avatar
hi all - does anybody have correct part # for Moog upper and lower Rear control arm rubber bushings? It’s for a 72 cutlass convertible with 10 bolt - 8.5inch differential - I’m looking for all four lower and the four upper (upper has the “mouse ear” bushing on top of the housing) thanks! ~ Joe R.
72442455 is offline
Old October 18th, 2018, 02:36 PM
nicks1966's Avatar
The number I have is a k5161
nicks1966 is offline
Old October 18th, 2018, 03:23 PM
Joe Ralph
72442455's Avatar
Is that one part # used for each of the 8 rear control arm bushings? Or are the two differential housing bushings different? And does this bushing include the metal sleeve that I need to press into the control arm? Thanks
72442455 is offline
Old October 18th, 2018, 03:47 PM
nicks1966's Avatar
I have it listed as all the bushings being the same, here is a photo of the bushing and the spacer used to install them. without the spacer I have collapsed the one side of the control arm.
Old October 18th, 2018, 04:16 PM
Joe Ralph
72442455's Avatar
i understand the spacer - but the photo looks like just a rubber bushing - no metal sleeve with it? (Never done this before - want to make sure I order everything I need) here’s photos of what I have
72442455 is offline
Old October 18th, 2018, 04:40 PM
Joe Ralph
72442455's Avatar
Never mind - I see it’s just black metal sleeve - was hard to see - thanks! Got them ordered
72442455 is offline
Old October 18th, 2018, 04:56 PM
Not only are all eight bushings exactly the same part number, but six bushings that go into the upper and lower control arms all get pressed in from the same direction. The arms are the same on each side - they are not RH/LH. Only the two bushings in the rear axle get installed in different directions.
joe_padavano is online now
Old October 19th, 2018, 02:35 AM
Joe Ralph
72442455's Avatar
thanks Joe - are the lower control arms directional? Like a front and back?
72442455 is offline
Old October 19th, 2018, 04:07 AM
Yes. The holes for the sway bar go towards the back.
Old October 19th, 2018, 04:23 AM
Joe Ralph
72442455's Avatar
thanks! 👍🏼
72442455 is offline
Old October 29th, 2018, 01:19 AM
Joe Ralph
72442455's Avatar
it occurs to me that I’m not sure how sway bars attach to the lower control arms as mine has no sway bar (yet)
Does the long slot oval hole go towards the front of the car? (That would be my guess but just wanted a second opinion)
72442455 is offline
Old October 29th, 2018, 03:12 AM
nicks1966's Avatar
Yes the oval slot goes towards the front.
the arms you have do not look to be boxed for a sway bar are you going to use spacers or box the arms?
inserts to box the control arm
https://www.summitracing.com/parts/o...SABEgLey_D_BwE
Old October 29th, 2018, 08:37 AM
Joe Ralph
72442455's Avatar
thanks! Yeah they are not boxed yet. The inserts have to be welded in correct? I currently do not have accesss to a welder. Race against time to put her back together before winter storage - she might have to run unboxed for the time being. Thanks for the info though!
72442455 is offline
Old October 29th, 2018, 09:06 AM
My442's Avatar
Question
Joe, do you have documentation on this?
My442 is offline
Vistabrat72
February 22nd, 2018 05:35 PM
dennis_30281
January 18th, 2018 11:24 AM
Harmon
Drivetrain/Differentials
July 28th, 2014 12:07 AM
montvaleplace
April 11th, 2012 12:59 PM
t bell
October 23rd, 2009 08:26 AM
Quick Reply: Moog rear control arm bushing part #?
