Moog front coil springs std or HD
My front coil springs appear to be original. Both of my front control arm bumpers have bumped many times in the past and could use replacement.
I want to replace my front coil springs.
Rockauto (moog) offers a std rate and heavy duty rate #s 5382 and 5450, I'm inclined to go with the 5450 HD offering.
I would like to hear some opinions from someone who has bought either or both before
my car is a 72 supreme
Keep in mind all of the Moog std springs for this year and model have a higher spring rate than stock. So getting a Moog std would still be stiffer than the originals. And the original ones would be saggy anyway.
Decide what is more important - handling or ride quality, and go from there.
I got the HD front ones for mine, which have a rate just a bit higher than that of the factory FE2 suspension springs. They will be installed in a few weeks.
Hi Rob
I dont know what FE2 is? a performance option ? I like performance
whats more important handling or ride quality ? well I was hoping to get both
or some reasonable trade off between the two, right now I get an unreasonble comprimise of neither
I can wait two weeks for your ride report
Dean
Dean
Hi Rob
Dean
Dean
I got the Moog HD REAR springs but they are too stiff - the back feels jittery. The spring rate of those are 167lbs, the rate for 4 speed cars. The FE2 rate for auto trans should be 122lbs. The Moog STD springs are 121.5lbs, so I will change them out. The Olds stock regular springs were way under 121lbs.
I will give the ride report early October!
back in the late 90s i ordered a set of springs for my Rallye 350. when they ask if i wanted standard or HD, i said HD just thinking thats what would have been original and not knowing the differance. i have never been happy with the harshness of the ride over stock. if i wanted a sports car that would be one thing but all i ever wanted is a fun and comfortable driver.
FE2 was the 442 suspension that came with the W29 or W30 option packages.
The front HD springs are 450lbs. The Olds FE2 springs were 435lbs - pretty close.
The convertible is heavier, so I am hoping the ride will not be harsh. Since I had added another 100lbs of options and dynamat, those extra 15lbs should be fine.
The STD Moogs are 358, so they are way too low for FE2 specs. I THINK STD Olds springs were 335lbs.
There was a huge rate range for the rears; more than I imagined.
FWIW, I installed Moog 5536 Front / 6321 Rear last summer, and am pleased with both ride, stance and handling... Not sure the spring rates on those but it's available online.
Also installed shocks - KYB KG4513 Front / KG5504 rear; I imagine these are part of the equation
That is on a '70 big block cutlass convertible, not sure if that is an identical application to yours...
I will be installing standard Moog springs this week on a 72 vert. Original springs and some totally ghetto spacers are being replaced. I'll report when done. BTW - went with the variable rates in the rear and love them. Not too stiff, but I'm used to driving a SUV with 20 inch rims on 40 series tires.
I don't find the ride to be harsh at all. There is no float - that could be perceived as stiff I suppose. Added bonus - a lot less brake dive. The only drawback is the front end is riding a touch high for my tastes.
Very nice to hear - pat yourself on the back for a job well done!
I got mine mostly assembled, just need the wheels on and aligned. My lower bushings were horrible.
Springs went in easliy - surprisingly....
