Loose steering
Old May 30, 2019 | 05:36 PM
brown7373's Avatar
Loose steering
My 72 Cutlass Supreme convertible wanders when the road has dips or uneven pavement. On a flat or level road, it drives straight as an arrow. I can take my hands off the wheel and it will continue straight. But it seems like if the road has a few dips, I have to chase the steering to keep it straight. I replaced all the bushings, springs and ball joints when I converted to (factory) front disk brakes. Any thoughts on what I should look at? It almost feels like the steering is on a rubber band. If it gets pulled one way or the other it's rubbery.
Old May 30, 2019 | 06:59 PM
RetroRanger's Avatar
72 Olds CS
is the alignment set to the factory castor setting ? Increasing the caster makes the front wheels just want to go straight, i had my car aligned last year and the guy agreed more caster is better and he dialed in as much as he could get IIRC +2° on each side .
Old May 30, 2019 | 09:34 PM
Take it to a reputable alignment shop. Have them set as much positive caster as they can get, .5* negative camber, and 1/16 toe in.
Old May 31, 2019 | 06:54 AM
brown7373's Avatar
I'll have to get it realigned with more caster and see if that helps.
Old May 31, 2019 | 09:30 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Inspect the inner/outer tierods pitman and idler arms the upper/lower control arm bushings and ball joints. Then get it aligned. Steering box lose?
Old Jun 1, 2019 | 05:43 AM
Sugar Bear's Avatar
X2 inspect the front suspension and steering components closely before alignment. Worn parts cannot hold the alignment, it will vary/wander constantly as much as there is movement in the worn parts.
Wide tires will increase following/tracking of road imperfections. What width and profile tires are in use?
Good luck!!!
Old Jun 3, 2019 | 05:06 AM
brown7373's Avatar
BFG Radial T/A 225/70R14 on Factory wheels. 10 months old.
brown7373
Jan 29, 2015 05:40 AM
MrTorresJr
Nov 6, 2013 07:34 PM
67townsedan
Sep 16, 2013 03:25 PM
White_Knuckles
Jun 17, 2013 02:41 PM
Cutdawg78
Apr 14, 2012 02:48 PM
