Installed Summit Racing Sway Bars
Old Dec 11, 2015 | 01:56 PM
BAFRAYD's Avatar
I recently picked up these Summit Racing sway bars for my 74 cutlass:
SUM-720202 (Front)
SUM-720209 (REAR)
The front bar was a direct bolt in piece. The rear required me to drill 2 holes in each lower rear control arm. Very simple to install, definitely a beginner level job.
I am really impressed with the difference that they made. The car doesn't wallow around in a straight line nearly as much as it used to and stays very flat through the turns.
Eric
Old Dec 11, 2015 | 03:01 PM
RetroRanger's Avatar
72 Olds CS
nice!!! sway bars can make a big difference. I upgraded my fr to 1.25 and added a 1" in the rear like you i noticed a big difference in straights at speed over risers and in the corners for sure...if you dont have a fast ratio steering box in your car add that to the list it really improves feel when driving.
Old Dec 11, 2015 | 08:14 PM
BAFRAYD's Avatar
I don't have one, but want one. Which one did you use?
Old Dec 12, 2015 | 03:03 PM
72 Olds CS
Lares 974, very happy w it about $200 from rock auto and comes w a new rag joint. Bolt in and uses your original ps hoses no adapters.
Others have posted they liked the jeep gc box which can be a little less $ but no warranty and needs adapters for ps hoses. Look on rockauto for your car for the exact box but the 974 is pretty common.
Old Mar 3, 2016 | 11:55 AM
Alex72cutty's Avatar
I'll have to order some. Have you guys changes your rear control arms?? I'm looking for a tighter ride. I have the gc gearbox. It's ok but no warranty.
Old Mar 3, 2016 | 12:31 PM
72 Olds CS
hey Alex
I have the boxed rear LCAs and 1" rear sway bar from parts place, i rebushed the rear UCAs w new rubber bushings. I also got the 442 rear frame braces OE GM but theres lots of after market options for those too
marxjunk
Oct 2, 2015 07:38 PM
Dead Reckon
Non-Olds Engines
Mar 15, 2015 07:10 PM
Creativeindy
Sep 10, 2012 12:21 PM
cutlassgal
Sep 6, 2010 07:28 PM
cutlassgal
Sep 5, 2010 09:17 PM
